Doors won't lock???
Doors won't lock???
2005 Mustang GT. Doors won't lock. They move up and down, but when supposedly locked, you can still open the doors. The remote works, and it locks it, but again, you can open the door. Anyone have any suggestions or a similiar problem? It only has 13,000 miles on it!
Thanks
Logan
Thanks
Logan
Water leaks messing up your electronics in the doors. The 05 to 08's had a lot of problems with this. After it rains really good check your floors and see if they feel wet. I am pretty sure that's what the issue is though.
I figured out what the problem was on my 2008 Mustang. Of course AFTER I spent $130 at the local dealership. The problem occurs when you screw the lock **** too far down. If you screw it too far down when you lock the doors it catches at the top of the door panel and thus won't allow it to go down far enough to lock the door. Loosening the **** will allow the car to lock. The only problem is that it vibrates up and down and it may fall off if too lose. I'm thinking a little bit of lock-tite or nail polish or even some Teflon tape might help keep it in place.
09-25-2015 06:58 PM
