Cervini's Body Kit Removal
For those of you on the forums that have been following my H2 Damage drama...i'm a couple of days away from replacing the fender that was damaged. My only problem is that I do not know how to get theCervini's body kit components off below the door - next to the fender. Has anyone ever seen this done, or perhaps installed and can describe the process so that I can do the opposite?
Any help helps y'all!!!
Thanks!
Thanks!
RE: Cervini's Body Kit Removal
I didn't actually install it, but I saw the parts prior to install.. There are screw holes all across the top of the rocker panel, they screw into the door sill. There are a few screws in the front wheelwell and a few in the rear wheelwell, and there's also double-sided tape in..... Just the rear, I think. MIGHT be some in the front.
Just try to follow the line of the part, remove all the screws, and whatever doesn't pop right off, there's tape under it. Bust outa hairdryer, some goo-gone, and an exacto knife.
I would say fishing line, but that'll be impossible to get around the body lines. Good luck!!!
Hey, no problem man. Glad to be of assistance. Sorry to hear about your H2 problem.
Question though - I JUST had my side exit kit installed last week. Couldn't you have just revved at them to let them know you were there?? I know my exhaust is louder than my horn (stock manifolds/h-pipe)!!!
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
