Sponsored by:
Sponsored by:
275/45R18 on stock 8.5" rims?
Old 04-07-2008, 12:59 PM
tlpvt
tlpvt's Avatar
Default 275/45R18 on stock 8.5" rims?
stock GT with stock polished aluminum 18" (8.5)
has anybody had any rubbing issues with 275/45R18 all over?
or would 255 width be better?
tlpvt is offline
Old 04-07-2008, 01:08 PM
Leoleo
Leoleo's Avatar
Default RE: 275/45R18 on stock 8.5" rims?
255 is the widest you should go on 8.5 rims.
http://www.1010tires.com/TireSizeCal...?action=submit
Leoleo is offline
Old 04-07-2008, 01:19 PM
99flhr
99flhr's Avatar
^ I just put 275/40 HTR Z II`s on the stock 8.5" wheel
Sumitomo recommends a minimum of a 9" wheel for this tire. Visually I see no difference in sidewall "bulge" between this and the 255/45`s I mounted on the front. Drives fine and has a sharper feel and quicker turn in than the stock BFG`s.
Car has Eibach Prokit springs, no fitment issue
99flhr is offline
Old 04-07-2008, 01:41 PM
tlpvt
tlpvt's Avatar
ORIGINAL: Leoleo
looks like 8.5" is the minimum width for 275's; for example:
http://www.michelinman.com/tires/lux...specifications
tlpvt is offline
Old 04-07-2008, 01:43 PM
whtcanbrwnd04u
whtcanbrwnd04u's Avatar
i have 275s on a 17x8 for the track
whtcanbrwnd04u is offline
Old 04-07-2008, 03:38 PM
rubah_dmb
rubah_dmb's Avatar
does any one have pics of 275's on the 8.5...?
rubah_dmb is offline
Old 04-07-2008, 03:47 PM
Nuke
Nuke's Avatar
I did a search on tirerack for various brands of 275/45/18 tires. Of the 2 tiresthat I sampled, 8.5" was the minimum recommended width.
Nuke is offline
Old 04-07-2008, 05:40 PM
w1ck3dr1
w1ck3dr1's Avatar
is there a way you can tell how wide your tire is without taking it off?
w1ck3dr1 is offline
Old 04-07-2008, 05:46 PM
moosestang
moosestang's Avatar
ORIGINAL: w1ck3dr1
If you have stock 17's they are 8 inch, if they are stock 18's they are 8.5 inches wide. If you have some aftermarket rims and you aren't sure, you could always put something across the outside and inside lips and stick a tape measure inbetween to measure the width.
moosestang is offline
Old 04-07-2008, 06:31 PM
Stkjock
Retired Mod
Stkjock's Avatar
275/45 are approved on an 8.5 rim from several companies. the issue as i recall is that they are pricey and found on high end cars for the most part
I went with 265/40 DRs as an alternative
Stkjock is offline
Quick Reply: 275/45R18 on stock 8.5" rims?
