Removing dealer decal?
RE: Removing dealer decal?
ORIGINAL: 157db
NEGATIVE
You dont want some $5 an hour washboy whos not trained
in sticker removal doing the job. Do it yourself so you can
control the method used.
The search function is your friend.
https://mustangforums.com/m_4892204/tm.htm
ORIGINAL: Boozshey
Take it back to them and tell them to get rid of it...
ORIGINAL: whtcanbrwnd04u
What an idiotic remark. If this so called "$5 an hour washboy" messed something up, the dealship WILL fix it.
ORIGINAL: 157db
NEGATIVE
ORIGINAL: Boozshey
worker and the stealership is making zero from the repair. Yea they will
put 110% effort into THAT repair. NOT. You do the math and tell me how
it come out.
Idiot?
Who me?
Dont think so.
If It is Vinyl, use a hairdryer, to soften, try to lift a corner then get some lighter fluid under the edges and peel it off little by little. Don't use plastic scrapper use a piece of soft wood then clean the surface with some lighter fluid and the job is done
ORIGINAL: 157db
Then you have a "FIXED" Stang by some underpaid stealership bodyshop
it come out.
Idiot?
Who me?
Dont think so.
ORIGINAL: 157db
NEGATIVE
ORIGINAL: Boozshey
it come out.
Idiot?
Who me?
Dont think so.
how to remove decals from cars
if you are removing a decal from a car that is on a painted area, don’t use a metal razor blade as its easy to scratch the paint. Depending on the size of the job (i.e. small or large) I know of 2 products. There is a video demo at www.decalstickerremover.com. (one does big areas and the other small areas) Hope this helps. P.S if you need a cheap product that is chemical free to remove the goo or adhesive, try eucalyptus oil (its chemical free and available at most supermarkets).
