Sponsored by:
Sponsored by:
Removing dealer decal?
Old 04-11-2008, 09:40 AM
jmy2469
jmy2469's Avatar
Default Removing dealer decal?
Can anyone tell me how I can remove the dealer decal that is on my rear bumper?
It has to go. Thanks
jmy2469 is offline
Old 04-11-2008, 09:41 AM
marcuskeeler
marcuskeeler's Avatar
Default RE: Removing dealer decal?
little more info would be needed really. is it just vinyl, or raised plastic embossed or what?
marcuskeeler is offline
Old 04-11-2008, 09:44 AM
jmcnh
jmcnh's Avatar
Hair dryer or heat gun but don't heat it too much. Something plastic to scrape it with.
Good luck.
Jeff
EDIT: Assuming it's vinyl
jmcnh is offline
Old 04-11-2008, 09:54 AM
waykooljr
waykooljr's Avatar
I peeled my vinyl decal off with my fingers, used a bit of WD40 sprayed on a rag to remove any adhesive left on the car, washed it and applied some wax.
waykooljr is offline
Old 04-11-2008, 09:56 AM
Boozshey
Boozshey's Avatar
Take it back to them and tell them to get rid of it...
Boozshey is offline
Old 04-11-2008, 09:59 AM
Leoleo
Leoleo's Avatar
Took mine off before I left the dealership. Handed it to my salesman who was laughing with me.
Leoleo is offline
Old 04-11-2008, 11:06 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: Boozshey
NEGATIVE
You dont want some $5 an hour washboy whos not trained
in sticker removal doing the job. Do it yourself so you can
control the method used.
The search function is your friend.
https://mustangforums.com/m_4892204/tm.htm
157dB is offline
Old 04-11-2008, 11:47 AM
Bluestar
Bluestar's Avatar
That was my first "Mod", took it off before I got into the Car for the First Time at the Stealership....2nd mod came before I got into 5th gear, pulled over, and disabled the Seat Belt Warning Chime
Bluestar is offline
Old 04-11-2008, 11:48 AM
ryan1994mustang
ryan1994mustang's Avatar
how do you disable the seatbelt chime? my roommate has an 04 lincoln ls and he never wears his seatbelt, and that chime gets annoying. im assuming its the same between the LS and a mustang.
ryan1994mustang is offline
Old 04-11-2008, 03:53 PM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: ryan1994mustang
Its not the same
RHFM to find out how for his 04 Lincoln.
Or RYFM and try the sequence to turn it off.
157dB is offline
Quick Reply: Removing dealer decal?
