Sponsored by:
Sponsored by:
door handle is coming off
Old 05-09-2008, 03:28 PM
brendend
brendend's Avatar
Default door handle is coming off
my passanger door handle is coming off! its getting really loose and i think it well eventully come off.. how can i fix this
brendend is offline
Old 05-09-2008, 03:29 PM
kngdaka
kngdaka's Avatar
Default RE: door handle is coming off
door handle delete
Never heard of this one to be honest. If it's still under warranty take it back and see what they do.
kngdaka is offline
Old 05-09-2008, 03:31 PM
pascal
S197 Section Modder-ator
pascal's Avatar
You have to remove the door panel and see if some bolts are loose or if the handle arm is broken inside.
Is it the side that rubbed against that deer this winter? If so, my guess is that the shop didn't get everything so tight.
pascal is offline
Old 05-09-2008, 03:32 PM
157dB
Cut & Paste Expert
157dB's Avatar
http://iihs.net/fsm/?dir=462
http://iihs.net/fsm/?dir=466&viewfil...ded%20View.pdf
157dB is offline
moosestang
moosestang's Avatar
Your door handle will not fall off. In order to fix it you'll need to remove the interior door panel, peel back the plastic cover and pop open a plastic clip that attaches to the metal rod going to the door handle. Pull on the metal rod and hold it while closing the clip in order to take up the slack.
moosestang is offline
Old 05-09-2008, 03:36 PM
brendend
brendend's Avatar
yes pascal its the side that tried to be friends with the silly deer.
brendend is offline
Old 05-09-2008, 03:38 PM
pascal
pascal's Avatar
There's your answer...
pascal is offline
Old 05-09-2008, 03:41 PM
brendend
brendend's Avatar
i figured that was the problem... the shops work isnt really holding up to well.. while clay baring the car the other day i found so much crap wrong with the paint. it looks like they didnt fully clean the door off before they painted. theres what looks like dirt under the paint. some spots you can see that the bondo wasnt fully sanded.. im getting sick of it. im about to spend the money and have it all redone.
brendend is offline
Old 05-09-2008, 03:45 PM
grampa_stang
grampa_stang's Avatar
Sweet link!!
grampa_stang is offline
Old 05-09-2008, 03:51 PM
pascal
pascal's Avatar
I feel for you brended...
You are not to blame one bit either.
Different Country, stock in the winter etc...
Here's what you do... Get you insurance adjuster and show him the mess and see if they'll go half way in fixing it again in your area by a reputable shop.
You have grounds in that ,you didn't have a choice to where you wanted the car to be fixed at, since the crash happened miles away from home.
pascal is offline
Quick Reply: door handle is coming off
