Replace Door Subs Without Cutting Anything?
RE: Replace Door Subs Without Cutting Anything?
This is what you need.
http://www.pioneerelectronics.com/PU...llow/TS-SW841D
Now they are not going to rock like 2 12's or anything but the are the best stock upgrade there is. And the bolt in with no cutting
ORIGINAL: CroDalmatinac
You still need to cut for the Pioneers to fit. I had them and it wasn't worth the hassle.
ORIGINAL: jmcnh
Are you driving these with the stock amps?
^ sounds better than stock, a little more low end thump. Some people compare it to my friends 5.0 with a single 10 in a box running about 300 watts through a Zappco amp.
