LCA bolts/nuts part numbers
I installed a set of LCAs in my car and re-used the fasteners. Now, the rear of my car is making all sorts of concerning noises. I now know that you arent supposed reuse the parts. Maybe I'm just dumb, but I cant seem to find the part numbers for the LCA fasteners. The guy I called at the dealership wasn't any help. He didnt have a clue what I was talking about. Can you guys give me the numbers? Or direct me to a place that can help me? Thanks!
RE: LCA bolts/nuts part numbers
There is no need to replace the bolts It is a common misconception that the bolts are TTY.
They are not.
As long as you torque them to the proper spec 129Ft. Lbs and use some loctite you will be fine.
What kind of LCA did you install? Poly bushing or Spherical?
They are not.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
