Sponsored by:
Sponsored by:
Hand Held Torch? Need help ASAP
Old 06-14-2008, 05:36 PM
redfireshaker06
redfireshaker06's Avatar
Default RE: Hand Held Torch? Need help ASAP
Someone tell me how to fix it with just tools W/OUT damaging the tailpipes? I can take it off the car
redfireshaker06 is offline
Old 09-03-2012, 05:28 AM
metroplex
metroplex's Avatar
Old old thread, but I had to do this again over the weekend.
Use a MAP torch (available from Sears, Lowes, Home Despot). It WILL get the hanger hot enough to bend easily. Once it turns red hot, use a hammer/mallet and pound it into the shape you want. However, this works well with 409/304 stainless. Do NOT do it on aluminized steel because it removes the aluminized coating causing it to corrode faster.
I tried using a long open ended wrench but it applies too much force on the welds to my liking.
metroplex is offline
Old 09-03-2012, 02:38 PM
prochargedGT
prochargedGT's Avatar
^+1 map gas will get it nice and red.
prochargedGT is offline
Old 09-03-2012, 02:58 PM
baddog671
baddog671's Avatar
On my old Magnaflow setup I just bent them by hand...
baddog671 is offline
Old 09-03-2012, 03:15 PM
metroplex
metroplex's Avatar
My Ducati will turn the exhaust pipes red hot just by idling!
Old 09-03-2012, 04:20 PM
moosestang
moosestang's Avatar
Originally Posted by redfireshaker06
Its already attached to the tailipipe, its part of the kit thats already on the car
Take it off and use a BFH!
moosestang is offline
Old 09-03-2012, 04:21 PM
moosestang
moosestang's Avatar
My Buell does also, but it's mostly because the headers are so freaking thin.
Old 09-03-2012, 04:22 PM
moosestang
moosestang's Avatar
Shame on you for digging up this relic!!!!!
Old 09-03-2012, 04:48 PM
stephen1371
stephen1371's Avatar
My exhaust shop uses a long breaker bar to go through the muffler and then bends to make it centered coming out the rear, you can probly do the samething
stephen1371 is offline
Matt's 95 Stang
10-05-2015 07:16 AM
RCS02v6
09-29-2015 01:46 PM
nboost
09-16-2015 05:35 AM
Quick Reply: Hand Held Torch? Need help ASAP
