Sponsored by:
Sponsored by:
which replacement battery??
Old 01-25-2014, 09:28 AM
  #21
Black Fire
Black Fire's Avatar
Originally Posted by Matt's 95 Stang
I will not use a Diehard again. I had to replace my '95's D.H. twice in one year, them they stopped making the battery so I had to get one with less cranking amps and that one soon died out on my too.
I am getting ready to replace my current OEM battery in the '11 as it will die after about an hour of listening to the radio when the car is not running.
Matthew
And you expect the battery to maintain a good charge after this ?
And then you expect the alternator to charge your battery back to full afterwards right ?
Batteries usually last on average of 5yrs if maintained correctly.
A full charge is 12.6 volts or higher. An alternator is NOT a charger it is a maintainer. If you use the battery for extended periods with the engine off then you can expect to have problems because you are draining more charge then the alternator can give back. An overnight trickle charge is usually sufficient to bring the battery to full charge.
I worked for Interstate Batteries and as someone else in this thread said they are built by Johnson Control in fact JC makes Sears DH, GM Delco, Mopar, Autozone etc... JC has about 45-50% of the US market share.
And Optima's are garbage, I wouldn't take one for free.
Black Fire is offline
Old 01-25-2014, 11:24 AM
  #22
Goldenpony
Goldenpony's Avatar
I bought an Optima Red. It didn't show me anything special-except for a high price.
Goldenpony is offline
Old 01-25-2014, 07:02 PM
  #23
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
I had no problem with my old Ford OEM battery in my 85 Fox when I would go to the drive in movie and have the radio going for 2,3,4 hours watching movies and the car starting right up. Cant do that with my current OEM battery and it has less time on it.
Matthew
Matt's 95 Stang is offline
Old 01-25-2014, 08:20 PM
  #24
Cruzinaround
Cruzinaround's Avatar
Optima Yellow deep cycle here. Purchased to retain maximum cold cranking amps in extended time in sub-freezing temperatures. I tend to be excessive in case of worst case scenarios.... And when the big freeze hit last time.... After 12 hours of sitting in -8 fahrenheit temperature. I noticed the OEM battery was slow to crank the vehicle.... So I went deep cycle.... Knowing how they serve me well on my ATV's, and Boat.
Now I don't worry so much. And the Battery has a 3 year warranty...bonus.
Cruzinaround is offline
Old 02-04-2014, 01:33 PM
  #25
Derf00
Gentleman's Relish
Derf00's Avatar
Most newer batteries are shiz. With the exception of the OEM battery in my 2000 V6 that lasted 6 year (3 in cali and 3 in AZ) no other battery has lasted more than 2 years here in AZ. I refuse to pay 170+ for something that doesn't perform any better than a $100 AutoZone battery.
It's really cool how about the two or three year mark when the free replacement warranty is about to wear out, the battery just up and dies or stops holding a charge. I just go and get a free battery replacement. It's not just my car, it's also my daughters Escape.
Deep cycles are good if you park the car for long periods of time or run things like a stereo for many hours without running the car. The downside is that most of them do not have the CA or CCA ratings of the regular celled batteries
Derf00 is offline
Old 02-06-2014, 12:13 PM
  #26
ThaiCobra
ThaiCobra's Avatar
duralast gold. $100. I like it, no probs.
ThaiCobra is offline
Old 02-07-2014, 08:49 PM
  #27
Joenpb
Joenpb's Avatar
Optima batteries are made in Mexico now and the quality has dropped. Quite a few have been reported as dieing after only 2-3 years.
Odyssey is a quality battery made in America, but you pay more for one. Its basically a MIL SPEC AGM.
Joenpb is offline
Old 02-08-2014, 08:54 AM
  #28
slickman
slickman's Avatar
Sears DieHard Platinum Battery here! awesome cranking amps and no liquid to worry about.
slickman is offline
Old 02-08-2014, 11:21 AM
  #29
DAD_23
DAD_23's Avatar
I'm an Interstate fan myself. Had great luck with them in the cold.
DAD_23 is offline
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: which replacement battery??
