turbo parts are here!
RE: turbo parts are here!
ORIGINAL: one eyed *****
will do, i plan to tac em all together,then hand them off to my dad,hes been a welder for 35 years.
tomb,i have not forgot about your tail lights,ive just been real busy,can you believe today is the first time i have washed my car since we did the cruise?
ORIGINAL: pascal
Good luck *****.
I can help you with welding (aestheticaly beeds) for the ones that will remain exposed.
Unless you grind down everything and powder coat.
Good luck *****.
I would say try to talk to Justin from VMP and he probably has the piece to weld into the intake tube for the maf. That way you can have a clean setup. I had planned on doing a electronic cutout on the downpipe so i have the option to run it back to the catted, h exhaust or just straight down pipe. I was intending on building some turbo manifolds that just go straight forward.
couple new items showed up today
header wrap-everything is getting wrapped and a fat turbo blanket for the turbo also
drain fiting for the turbo and the coupler for the turbo to intercooler piping 2.5" to 3"
as i get closer with all the parts here i will post a list with all the prices i paid,so if anyone is interested it would be a good start for them.
