Sponsored by:
Sponsored by:
275/40-20 Fronts and 315/35-20 Rears Anyone?
Old 06-30-2008, 01:24 PM
mhconley
mhconley's Avatar
Default 275/40-20 Fronts and 315/35-20 Rears Anyone?
I tried this question in another post and gotonly one answer that was more a comment on the post.
I am considering a wheel and tire package advertised as fitting the S197. 20x9 (42mm offset) wheels with 275/40's up front and 20x10.5 (56mm offset) wheels with 315/35's in back. These tires are freakin' huge. Is anyone running these tire sizes? Pictures please.
I know they're 1.6" taller than the stockers but think the bigger tire would take some of the harshness out of the 20's and would fill out the stock ride height wheel well's nicely.
Martin
mhconley is offline
Old 07-01-2008, 08:06 AM
mhconley
mhconley's Avatar
Default RE: 275/40-20 Fronts and 315/35-20 Rears Anyone?
Nobody? I may need to buy them and post pics myself...
Martin
mhconley is offline
Old 07-01-2008, 09:13 AM
fireball coatings
fireball coatings's Avatar
I have 245 40 20 front (8.5" rim 27.7" tire hieght)and 305 35 20 (10" x 38.25" tire height) rim with NITTO drag radials in the back. The car is also lowered with the Eibach pro kit. I had to install the Steeda adjustable pan arm bar becuase the rear end was 1/2" out of line to the body....which is apparently typical for these cars. The one side was hitting until I lined it up centered. Now it barely touches on a big high speed dip in the road.....but nothing to worry about.As you can see the 305's are tight fit if the car is lowered.....but your rims have more offset.....the 315's might be fine....as Ithink there is more room to go inside ......for fatter tires than the 305'S if the rims have more offset.
The taller tire height does make the car ride better....not as rough as rubber band tires.
Post pics if you try it!!
fireball coatings is offline
Old 07-01-2008, 01:11 PM
siberian.mist
siberian.mist's Avatar
i wouldnt go bigger than 255/40/20 up front
siberian.mist is offline
Old 07-01-2008, 01:52 PM
pascal
S197 Section Modder-ator
pascal's Avatar
I know that with the right offset, you can go 10" up front without rubbing, but I'm not sure of the maximum tire width.
pascal is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
2007CalSpec
09-09-2015 05:37 PM
robjh22
Suspension
09-08-2015 12:47 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 275/40-20 Fronts and 315/35-20 Rears Anyone?
