HELP Loaded tune, car won't start
I bought a used SCTxcal2 with three Brenspeed tunes. I loaded up LiveLoad, connected the tuner to the computer, and clicked on the unlock button. I then took the tuner to the car and loaded up the 89 tune (I presume this was the canned tune that came with the Xcal?). Everything went well until I tried to start the car. It turns over but doesn't start. I then loaded up "return to stock" and the same thing happened. Now I have 3500 lbs of inert metal in the garage. Does anyone know how to fix this?
HELP, HELP, HELP!
HELP, HELP, HELP!
RE: HELP Loaded tune, car won't start
If you loaded a custom tune it definitely wont work since they are locked to a specific ECM. So that will explain problem number 1. Now ... I would think that returning to stock should have fixed it. Brenspeed might be able to answer the question ... but from what I have seen if you mess up your ECM you have to have it towed to the dealer and they can reload the factory code by looking it up via your VIN ... Good luck ...
No mods at all. I would really like to have my car for the holiday weekend, do you think I will have to have the ford dealer reload the factory tune? I did return it to stock, it spins over but doesn't start.
yeah, your dealer needs to return the car to stock....or you could wait for the right tune to arrive from Brenspeed....
call Brenspeed tho...they're good with customer service
I just recently bought a bbk cai and sct xcal 2 from another forum member... I havent got it yet but he only used it once and it came with 3 of brenspeeds tunes, will they work or do I need to buy another tune from brenspeed or bama?
ORIGINAL: Johnboy7701
