APR front wind splitter installed...thoughts (pics inside) - Page 3 - MustangForums.com
Old 07-20-2008, 11:02 PM   #21
2007CalSpec
2007CalSpec's Avatar
Default RE: APR front wind splitter installed...thoughts (pics inside)
Quote:
ORIGINAL: CapitalG
what do they do ?
They act as a step for midgets to work under the hood. [8D]
2007CalSpec is offline   Reply With Quote
Old 07-20-2008, 11:45 PM   #22
Krazyray
car looks sweet,clean install.
Krazyray is offline   Reply With Quote
Old 07-20-2008, 11:56 PM   #23
paydirt
paydirt's Avatar
hahahahaaha thats awesome. thanks for all the compliments guys. I really appreciate it.
Quote:
ORIGINAL: 2007CalSpec
Quote:
ORIGINAL: CapitalG
what do they do ?
paydirt is offline   Reply With Quote
Old 07-21-2008, 12:36 AM   #24
lrgnation
lrgnation's Avatar
Your car really looks bad *** but I am thinking that you take off the rear tint covers and do tint spray and leave the reverse light clear. And paint your rear emblem black. Then your rear will match up with your front a lot better and also do the tint spray on the 3rd brake light.
lrgnation is offline   Reply With Quote
Old 07-21-2008, 04:14 AM   #25
joestang08123
hey merdix9 i live in san antonio as well. love to see your car in person. get in touch with me.
joestang08123 is offline   Reply With Quote
Old 07-21-2008, 05:14 AM   #26
nite
Quote:
ORIGINAL: CapitalG
what do they do ?
"A Wind Splitters is a protruding flat surface in the front of a car that is designed to decrease front end lift and exert downforce. By creating a high pressure area on top of the wind splitter, high pressure air flow is restricted to flow underneath a car. With low pressure below the car, the effect of lift is reduced and a driver can gain from the extra traction and control."
http://www.aprperformance.com/index....&Itemid=49
nite is offline   Reply With Quote
Old 07-21-2008, 01:20 PM   #27
Allstar
Allstar's Avatar
do they amke this for the CDC classic chin??
Allstar is offline   Reply With Quote
Old 07-21-2008, 01:26 PM   #28
pat123
Nice car; great look
pat123 is offline   Reply With Quote
Old 07-21-2008, 01:52 PM   #29
paydirt
paydirt's Avatar
thanks so much for all the compliments guys. they might be able to make one for the classic, underneath the chinspoiler your going to need atleast an inch of flat space to put all the mounting screws through. I'm not sure if the classic is like that or not. than you just trace an outline of it onto a piece of cardboard and send it in to them and they can get you all hooked up. if you have any questions you can call APR at 909-594-3796
Old 07-21-2008, 03:53 PM   #30
deekum1627
deekum1627's Avatar
you car looks awsome im goin to have to get that too thanks for showing it off
deekum1627 is offline   Reply With Quote
mysterious water leak zsmart Convertible Tech 2 02-29-2016 09:33 AM
New Member orangeboom New Member Area 8 09-23-2015 10:43 AM
bolt keeps coming out between backing plate and caliper maestro1024 Classic Mustangs (Tech) 6 09-21-2015 03:40 PM
Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8 jaiidutch Motor Swap Section 2 09-14-2015 11:29 AM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 09:43 PM
2005, 2008, apr, avatar, custom, front, gt, install, made, make, mustang, putting, splitter, splitters, wind
