Sponsored by:
Sponsored by:
Homelink (non mirror) install
Old 09-09-2010, 01:55 AM
  #31
ResQman
ResQman's Avatar
Thanks mByers...
I appreciate your information. I have seen both of the threads that you have posted. Read them in detail. The thing I like about the high beam idea is that no one really knows that you have it. If your car is broken into, or stolen, the bad guys have your door opener and your car. Plus, it doesnt take a rocket scientist to figure out what those three buttons on your dash are for.
Since I have had my car stolen once, I wont make that mistake again. Stealth is better....
Just my 0.02$
ResQman is offline
Old 09-09-2010, 04:12 PM
  #32
KutenStang
KutenStang's Avatar
Just as a note, the 2011s overhead console is a little more cluttered than previous models. Mine has the passenger airbag off light and also the microphones for the Sync. It's going to be tight, but I think I can trim enough out of the airbag light bracket to get the homelink installed. Will take some pictures and post when I get it done.
KutenStang is offline
Old 09-09-2010, 04:34 PM
  #33
WeinerDog
WeinerDog's Avatar
They moved the Sync mic from the mirror to the console...and still don't offer a Homelink mirror?
WeinerDog is offline
Old 09-09-2010, 10:44 PM
  #34
asci01
asci01's Avatar
Originally Posted by ResQman
Thanks mByers...
Just my 0.02$
You just have to make sure power to the homelink is only on when the engine is on. That's the way I had mine wired. Not hard to do and the safest way to have homelink in your car.
asci01 is offline
Old 09-10-2010, 06:15 AM
  #35
mbyers
mbyers's Avatar
...2011s overhead console... [has]...the microphones for the Sync...
Are you sure about that? My microphone is on top of the mirror. When you put up pics, can you also put up ones showing the microphones in the console?
In one of the other threads, there is a pic of homelink in a console that as the airbag light, so you should be fine.
I have remote start, so I'm not sure what added wiring that adds to the console.
mbyers is offline
Old 09-10-2010, 01:03 PM
  #36
KutenStang
KutenStang's Avatar
After pulling the console apart, I found that there is no way that the homelink will fit. I trimmed a few unnecessary pieces and found that it just will not fit. And yes, the microphones are in the console on the left and right front of it. Also, the passenger airbag light is in the front/center of the console. If it were not for the airbag light, it would fit. So, until I find a way to "rework" the airbag light so it is functional, yet more compact, I will not be able to put my homelink in the overhead console. Sorry, no pics, but if you have an '11 Mustang with Sync, pull it down and you'll see what I mean.
Edit: I may be able to fit the Homelink in yet if I trim down the power connector and solder the wires to the power leads. This should trim out another 1/2 inch or so inorder to fit the unit in. Will have to try it out and see.
Old 09-13-2010, 07:08 AM
  #37
mbyers
mbyers's Avatar
yes, the microphones are in the console on the left and right front of it ... pull it down and you'll see what I mean.
I will do that (hopefully this weekend). I have a 'dome' on the top of my rearview mirror and, based on other threads, said that was the SYNC microphone.
Do you have a 'dome' on the top of your mirror?
What is the approx build date of your car (maybe they changed partway through the 11's)?
That should work. There doesn't seem to be much in that area of the circuit board, and I think I read somewhere that someone did that.
mbyers is offline
Old 09-14-2010, 12:20 AM
  #38
nothing
nothing's Avatar
those mic looking things on the right and left corner of the overhead console are sensors for the alarm system. if you wave your arm in the car with it armed it will detect the motion and the alarm will go off. the mic is on top of the mirror as others have said.
nothing is offline
Old 09-14-2010, 05:57 AM
  #39
mbyers
mbyers's Avatar
Originally Posted by nothing
those ... are sensors for the alarm system
That makes sense; as SYNC in other cars has only one mic as well.
I have heard others say that with the alarm system, things are pretty packed in the overhead console; that helps explains why as well.
mbyers is offline
Old 01-04-2011, 07:15 AM
  #40
mbyers
mbyers's Avatar
Over the holidays I finally got around to installing this in my car. I spend more time trimming the HomeLink versus trimming the over console. I was able to get away with only drilling holes in the console. So all the factory plastic posts (on the 'inside' of the console) are untouched.
mbyers is offline
Quick Reply: Homelink (non mirror) install
