Whats the purpose of the strut tower brace? iTs it functional?
well, it has been awhile...Imo, the "brace" is for looks. I bought one from steeda a long time ago. it is recomended that if you take it back off to get new nuts and blue locktite.
i would save the money, imo......that's 100-150 dollars towards a wet kit.
2 cents
2 cents
I could tell a very small difference in mine when I put it on. I have the polished Granatelli STB. WELL WORTH THE MONEY! Well worth it because I paid $40 for a brand new one from a guy off Craigslist. Awesome deal. I wouldnt pay full price for one though. Extremely small difference if any for daily driving. Like everyone says; mostly cosmetic.
Verts, maybe if it does not have slotted mounting holes.
The CS from moss is stamped to match the strut towers
and would provide more stiffening (if they even do) than
one that just mounts with slotted holes and OEM strut
bearing bolts/nuts.
bearing bolts/nuts.
Yes, it does help it's little bit in hard turning, that would be in combo with a g-track bar, front swaybar braces, shock tower brace, watts link, welded dual triangulated chasis braces and anything else that reduces roll and counter roll. This is assuming you already have better springs, shock, struts, swaybars. Clearly nothing will ever replace the joy at the utter difference these 4 items made initially when I compared it to canyon driving in LA. Anyone that can't feel tha massive difference between stock and of these initial change outs isn't alive I guess.
What you feel is not the issue, it's what the combination does to help keep all the tires as much on the ground as possible in hard turns ie reducing sway as much as possible.
Try taking a long freeway on ramp as fast as possible barley staying on the pavement with the stock suspension, then with the changed out one, there is no comparison IMO. Erik
For those that think it doesn't do anything, consider this. When I put mine on, it didn't fit. I had to raise the front wheels off the ground to get the bolts to fit into the holes on the STB. Therefore, they move. If they move, there's chasis flex, and anything you can do to reduce that is good, IMHO.
Like with all suspension mods, it's a cumulative thing. They all add up.
