Sponsored by:
Sponsored by:
Panhard Bar VS Watt's Link? Weight difference?
Old 09-08-2008, 01:43 PM
buffguy
buffguy's Avatar
Default Panhard Bar VS Watt's Link? Weight difference?
Anyone been able to measure the weight difference between the panhard bar and brace compared to the saleen watt's link? I don't track the car. Would there be any need for the watts link? Maybe inprove traction on the street?
buffguy is offline
Old 09-08-2008, 03:19 PM
Ring of Fire
Ring of Fire's Avatar
watts link will improve traction slightly more than a panhard bar
Ring of Fire is offline
Old 09-08-2008, 03:27 PM
danbevsv6rumbler
danbevsv6rumbler's Avatar
I think the one or two watts systems i've seen are both listed around the $1K mark, versus a panhard bar is usually around $130-$160 depending on what you're going for (ie double adjustable with rod/poly, aluminum...)
Ask yourself if its worth going one way over another and you should have your answer
danbevsv6rumbler is offline
Old 09-08-2008, 04:00 PM
Argonaut
Argonaut's Avatar
The Watts link will weigh more without a doubt. Although I don't have numbers the PHB and brace weigh practically nothing, they are very light. Overall its probably negligible difference though, not something you are going to feel.
Regards performance - I personally have not driven a Watts link setup but have talked to and read posts from those who have. The consensus is for a Track car it may be worth the money if a) you are a good enough driver to exploit it and b) care about the small diff in laps times it may provide. For a street car I'd say the jury is out, some folks claim it makes the rear end feel more "planted" others think its a waste of money. IMO the only people who can really answer this accurately are ones who have considerable high performance (i.e. more than just normal street) driving experience with both systems. I know "F1Fan" qualifies (although he seems to be on sabatical recently) as does "Sam Strano". You might try PMing them.
The Fays2 Watts link is about $650, the Steeda about $1000.
Argonaut is offline
Old 09-08-2008, 06:21 PM
eolson
eolson's Avatar
My Saleen Watts link with all nuts and bolts, pumpkin cover weighed 41lbs.
The removed Steeda rear swaybar, HD links, Panhard bar and brace plus the stock pumpkin cover and the stock sheet metal boxing weighed 35lbs.
The original Mustang GT stamped iron rear swaybar, links, panhardbar and brace together removed originally weighed the most at 51lbs.
So at least with the Saleen rear "watts link" solution you are saving about 10lbs from stock, and getting more stabilty in turns with bumps and hitting the gas out of turns. Erik
eolson is offline
Old 09-08-2008, 06:26 PM
eolson
eolson's Avatar
To clarify, I had the watts link replace the all steeda swaybar, panhard bar and brace, which before that replaced the incredibly heavy stamped metal parts from Ford.
The stock panhard bar and brace seemd like weight lifting bars they were so heavy, really!
The watts link is the winner hands down for handling, the car simply stays on the ground now, period. Erik
eolson is offline
fcarpio
Suspension
11-16-2018 10:35 AM
Gene K
10-21-2015 11:37 PM
GimpyHSHS
09-18-2015 12:27 PM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Panhard Bar VS Watt's Link? Weight difference?
