Sponsored by:
Sponsored by:
Which gear oil to use?
Old 09-18-2008, 11:10 AM
avengence
avengence's Avatar
Default Which gear oil to use?
So this weekend I am switching to 4.10s. Which gear oil weight should I put in? I am just going to get royal purple. Its like 10 dollars a quart I think. I need to buy 3 and put 2.5 in right? Also it doesnt need friction modifier does it?
avengence is offline
Old 09-18-2008, 11:17 AM
CroDalmatinac
CroDalmatinac's Avatar
http://www.americanmuscle.com/royalp...0-gearoil.html
Amount you need is in the manual.
CroDalmatinac is offline
Old 09-18-2008, 11:45 AM
Argonaut
Argonaut's Avatar
The weight is: 75W140. Yes get 3 quarts.
I put the Motorcraft Synthetic in and it did require Friction Modifier. I purchased from the Dealer and cussed them out all the way home, the criminals charged me $22 per quart. Wont do that again.
Argonaut is offline
Old 09-18-2008, 12:25 PM
jimreinarts
jimreinarts's Avatar
Is there any truth to that of breaking them in with non syn oil, this was suggested from the gear manuf that i dealt with .
jimreinarts is offline
Old 09-18-2008, 04:05 PM
doctorstrobe
doctorstrobe's Avatar
The cars come stock with synthetic gear oil...
Oh, but I guess you mean when you swap in a new gear set. Yeah, makes sense. Your supposed to change the oil after break-in period so why put the expensive stuff in...
doctorstrobe is offline
Old 09-18-2008, 04:29 PM
JimsGT
JimsGT's Avatar
When I went 3.73's, my shop put in 2 qts Royal Purple 75/140 synthetic, and 1 bottle of Ford friction modifier. ($13.95 each for the RP, and $4.95 for the Ford FM)
Are you really supposed to use 3 qts??? Now I'm concerned, I had the swap done back in June, I've put on 3,500 miles since then, and now I'm noticing a slight noise on accel & decel at about 60 mph!!! I'm getting a little pissed...I also remember him not using the gear install kit, unless he had one laying around and didn't charge me! (Doubt it)
JimsGT is offline
Old 09-18-2008, 04:34 PM
157dB
Cut & Paste Expert
157dB's Avatar
Synthetic diff lube like factory and friction modifer.
S197 8.8 SPECS
Seems to me that I read a TSB about filling it all the way up to
the fill hole until it starts coming back out instead of the original
1" below the fill hole recommendation.
157dB is offline
Old 09-18-2008, 04:44 PM
grampa_stang
grampa_stang's Avatar
My installer used Royal Purple that had the friction modifier in too. But my clutch packs still moaned during slow turns. So I waited...broke the gears in by just driving around like granny..went through a few heat cycles and good to go. Drove for another 2 weeks, getting in a good wear pattern, then off to the dealer for new clutch pack and new gear oil, all under warranty. Worked out kinda sweet.
grampa_stang is offline
Old 09-18-2008, 04:47 PM
avengence
avengence's Avatar
The royal purple stuff has friction modifier in it. I think I am going to be running 85w140 or whatever it is. My friend is running that too cause he talked to ford and they said unless you are in a cold area you can run a higher weight. I am not sure if this all sounds right... what do you guys think?
Old 09-18-2008, 08:02 PM
BruceH
BruceH's Avatar
Learn it yourself. I'm done.
BruceH is offline
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
musnicki
09-23-2015 07:11 AM
Demodulates
09-18-2015 11:14 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Which gear oil to use?
