Stock LCAs with LCA relocation bracket?
will this be fine until i get an aftermarket LCA? i dont plan on going to the strip anytime soon but will be putting in sportlines in the upcoming weeks
i believe id have to use the lowest setting since im going with such an aggressive drop with the sportlines....if im wrong please let me know
id be doing the install for both myself, i was under the car installing my panhard bar and brace and took a look at what would be involved with the control arm/relo. bracket install while i was under there. im confident in the fact that i could do it in about an hour with a helping hand
Yeah. It's not a very hard install. You might as well do both at the same time though because its only around $100 for the LCA's after you already have the brackets. You probably would be at the lowest setting anyways.
09-17-2015 07:57 PM
09-16-2015 07:53 PM
