Clear turn sigs on vista blue?
I have had a box of clears in my trunk now for close to 2-3 months. I don't have a shop, and the install looks damn near impossible without a lift.
I've decided that I'm going to drive over to my mothers this weekend and just try to do it w/ the car sitting on the ground. Hope I don't break something.
Here are SMOKED corners. Just installed them the other night, they were about $40 shipped from Ebay vendor. I did not want clear because they just looked to white. I think the smoked better matches the headlights.
I plan to do stealth bulbs when I get some extra $$.
Install was easy, and without a lift, only took 15 minutes max. Turn the wheels to the right to do the left and vice versa. Remove the screws and carefully pull back the fender liner to access the lights. Unclip the 2 clips at the outer edge, remove bulbs, and pull it out of the tab at the far end. Reverse process and you're done. Getting the new lamp tab into the slot at the inboard side is tricky but not impossible.
Some quick pics from the parking lot just now.
