Sponsored by:
Sponsored by:
Shift Pressure?
Old 10-12-2008, 05:50 PM
loaded6shooter
loaded6shooter's Avatar
Default Shift Pressure?
Those of you with auto and tuners what do you have your shift pressure set to? id like some firmer shifts out of my auto but im not sure what percentage to set it on....
loaded6shooter is offline
Old 10-12-2008, 05:56 PM
MrSandman
MrSandman's Avatar
Not sure, but I spin through first and chirp through 3rd with my bamachips 93 race tune at WOT.
What tune are you running with that C&L..? I would adjust the pressure by 5% until you find what you are looking for. If you are still running with a stock differential and gears.. you could probably max the pressure out without problems.
Your car is gorgeous, btw.. seriously.
MrSandman is offline
Old 10-12-2008, 06:00 PM
loaded6shooter
thanks man, im running the 93 race from bama too but stock gears and a peg leg....
Old 10-13-2008, 10:32 PM
FINGT
FINGT's Avatar
Can you adjust the pressure with SCT Tuner, I quess not ?
I have Brenspeed tunes and have been a bit worried for WOT shifting, it chirps on 3rd and the shift is very hard, you can basically hear the gear going on.
I just wonder how much these trannys can take.
I have stock differential and gears.
FINGT is offline
Old 10-13-2008, 11:38 PM
loaded6shooter
yeh u can adjust shift pressure for each shift....1-2 2-3 3-4 4-5
Thunderball
15
11-22-2015 11:49 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Shift Pressure?
