mgw shifter
There used to be a sticky created by "moosestang" that detailed how to refill the fluid through the transom (shifter) hole. Worked great for me when I changed my fluid.
It's as easy (even easier due to no filter replacement) than changing your oil. One refill hole at the top of tranny and a drain hole at the bottom. It can get really messy though...
Make sure to have the reservoir REALLY close to the drain hole or it will go EVERYWHERE. It's much thinner than motor oil and will splash all over if you're not careful. I'll try to locate that sticky for you guys.
I used RP synchromax, smooth as butter now. And after fighting with shift ***** for awhile decided to go back to a universal favorite, the pistol grip. best shifter grip I've ever used! woudn't trade it for the world. works with the MGW standard thread post.
pic:
pic:
