Strange squeaking sound from rear passenger tire
The last couple weeks my car has been making a slight squeaking noise when I slow down to make right turns. It doesn't happen if I come to a complete stop and then turn at a stop sign or a street light, but if I simply slow down without stopping to make one of those turns it sometimes happens. I'd say probably about 15% of the time... mostly, if not only, in the mornings when it's still cool outside. It seems to be coming from the passenger side rear tire/wheel. It would seem to sound like it's the tire making that sound, but I suppose it could also be the brakes. My car is an '06 V6 Pony Package with 28,000 miles. I've got stock rims and the tires are stock as well. I've had them rotated regularly and have never changed the brakes. The warranty expired in September.
If anyone has had this issue on their 'Stang or has any insight please chime in. Thank you.
hey victoria
do you have any mods in that area? lower control arms maybe... t-lok?
can't say i've had similar issues running STOCK, but with aftermarket parts i've had squeaks here and there.
will you be attending the socal cruise? maybe we could take a look at it for you.
hey victoria
Where exactly will the cruise be? If it's in the OC area I'd probably be interested... also depends on what day it is. I'd need to check my work schedule.
maybe its the LCA bushings? Could be anything you mentioned too but now might be the opportunity to "mod" the suspension! Could be as simple as the brakes.....which IMO is normal. The car drives fine otherwise?
Yup. Drives good as ever. This squeaky thing only started about two weeks ago... it doesn't seem to be affecting anything but who knows in the long term. Hopefully whatever it is it's nothing major.
I have an 05 V6 mustang and have run into the same exact problem. It would come from the right passenger side and only squeak on slow stops. Had my brakes changed and still had noise but not as much. I assume it could be the rotors but my mechanic told me the rotors are fine...unless he lied to me
I just started noticing the same annoying squeaking problem coming from my right rear tire area. Would like to get whatever it is taken care of car sounds horrible driving me crazy but don't know how to start going about fixing it. Sounds like something is rubbing or something is loose and the car is only a 2006 Mustang and it sounds like a piece of crap. Especially on the highways I can hear that noise all the time.
inyadreems
08-21-2015 09:10 AM
