Sponsored by:
Sponsored by:
biggest tire for 18x9
Old 11-09-2008, 06:57 AM
roushclone
roushclone's Avatar
Default biggest tire for 18x9
whats the largest tire i can fit on a 18x9 wheel. I currently run 255/45's in the front and i want something a little taller/meaner in the back, to fill the wheel well. Thanks
roushclone is offline
Old 11-09-2008, 07:30 AM
Toy4Bob
Toy4Bob's Avatar
I am running 275/40, and think I saw tirerack recommended upto 285 on a 9" rim, but can't remember for sure.
Toy4Bob is offline
Old 11-09-2008, 12:13 PM
bronxbomba63
bronxbomba63's Avatar
I think 275's are the widest you can go on 18x9's. Almost positive.
bronxbomba63 is offline
Old 11-09-2008, 01:03 PM
atldave
atldave's Avatar
Just be aware that running extra large tires will mean that your speedo will be off and Ford can't calibrate it. You'll need a custom tune for that.
atldave is offline
Old 11-09-2008, 01:29 PM
Stkjock
Retired Mod
Stkjock's Avatar
find the brand you want and check the specs
275s should be no issue, idk think even 285s would be ok, stay close to a 27.25 diameter and your speedo will not be off much
Stkjock is offline
Old 11-10-2008, 08:09 AM
MustangGT0405
MustangGT0405's Avatar
275 is the bigest I know of on a 9 inch rim.
MustangGT0405 is offline
Old 11-10-2008, 08:18 AM
howarmat
s197 Junkie
howarmat's Avatar
275 would be the best for the 9" inch rim but getting a tire that measures nearest to the stock 27.2 size is hard. The 275/40 is you best option. You will be about 1 MPH off at 60 MPH which really isnt anything to worry about.
howarmat is offline
Old 11-10-2008, 10:17 AM
AmericanSpeed
AmericanSpeed's Avatar
I run 275/40/18 in the rear
AmericanSpeed is offline
Old 11-10-2008, 01:26 PM
owero01
owero01's Avatar
I'm running 275/40 all the way around on 18x9s. Fits the wheel wells perfectly.
owero01 is offline
Old 11-10-2008, 01:30 PM
Texotic
Texotic's Avatar
i have 275/40/18 in front and 285/40/18 in back. both are on 18x9's. but i'm changing the back to 275/40/18's next time around. the 285's fit, but they are not the ideal size.
Texotic is offline
Quick Reply: biggest tire for 18x9
