Sponsored by:
Sponsored by:
changing tune
Old 11-13-2008, 12:28 AM
07torchgt
07torchgt's Avatar
Default changing tune
So I currently have my 87tune from brenspeed on and want to change to the premium tune, so I know I must run through a tank or two of premium gas. Im wondering if I will be ok loading the new tune on after only running through one tank of premium?
07torchgt is offline
Old 11-13-2008, 12:46 AM
Hufenstang
Hufenstang's Avatar
i never even ran through a tank, just let the car get low on gas then filled up on 93 and then loaded the tune.. everythign worked great.
Hufenstang is offline
Old 11-13-2008, 12:48 AM
Texotic
Texotic's Avatar
same here. i ran it down till it said 5 miles left on the computer, filled it with 93, and loaded the tune. no problems.
Texotic is offline
Old 11-13-2008, 06:42 AM
Nuke
Nuke's Avatar
I concur with what was said above. What tune are you loading? If you're going with an 89 or 91 tune and can get 93, then fill up with 93 after the tank gets low and load the 89 or 91 (if you're worried about it). You'll be at or above the octane of either. Whatever octane you're going up to, mixing it with 2 or 3 gallons of a lower octane won't hurt unless your tune is on the hairy edge.
Nuke is offline
whatsup62
10-16-2015 03:07 PM
97SN95GT
09-13-2015 09:45 PM
whatsup62
09-03-2015 01:38 PM
iculookin
09-02-2015 12:34 PM
Cin K
09-02-2015 07:50 AM
Quick Reply: changing tune
