Sponsored by:
Sponsored by:
stupid BMR a-arm brace!!!!!
Old 11-16-2008, 02:28 AM
miloman
miloman's Avatar
Default stupid BMR a-arm brace!!!!!
This thing really makes changing your oil a pain in the ****! I couldn't get the dang drain plug all the way out, so I had to let the oil drain for a couple hours. I didn't want to remove the brace. Looks like I will have to in the future though. I'll just stick it in the press brake at work, it only needs a slight bend. Anyone else have this issue?! Here is a couple pictures when I installed it a while back. Maybe I put it on wrong!?
Attached Thumbnails stupid BMR a-arm brace!!!!!-mike-073.jpg   stupid BMR a-arm brace!!!!!-mike-075.jpg
miloman is offline
Old 11-16-2008, 02:38 AM
scramblr
scramblr's Avatar
Why does it look bent? Or is that just the picture? I have one and although a tight fit, the plug comes out fine.
scramblr is offline
Old 11-16-2008, 02:56 AM
miloman
miloman's Avatar
That bend is a BMR bend. Plug would probably come out easy if the bar was straight.
miloman is offline
Old 11-16-2008, 02:57 AM
miloman
miloman's Avatar
Could I have possibly put the brace on up side down?
miloman is offline
Old 11-16-2008, 02:59 AM
miloman
miloman's Avatar
http://www.bmrfabrication.com/05Mustang/AAS001.jpg
Here's what the bar looks like off the car. /\
http://www.bmrfabrication.com/05Must...ortInstall.jpg
But this one doesn't have a bend in it. /\
miloman is offline
Old 11-16-2008, 04:00 AM
SteveB_RET
SteveB_RET's Avatar
I have the Bar on my 2007 Mustang. Yes the bar has a bend in it. and my only issue with changing oil is that I have to use a box wrench to take out the oil plug rather then a socket. My plug comes out just fine.
SteveB_RET is offline
Old 11-16-2008, 09:23 AM
mlcrycc
mlcrycc's Avatar
Enough room for this???
http://www.mossmustang.com/Shop/View...eIndexID=48224
mlcrycc is offline
Old 11-16-2008, 09:54 AM
EagleStroker
EagleStroker's Avatar
Originally Posted by mlcrycc
That's pretty slick right there
EagleStroker is offline
Old 11-16-2008, 10:00 AM
kpaulhus
kpaulhus's Avatar
I dunno??? That part would make changing the oil a breeze but i would worry about it accidently opening at some point?
kpaulhus is offline
Old 11-16-2008, 11:43 AM
Texotic
Texotic's Avatar
that's awesome! i'm going to get one and install it on my next change.
Texotic is offline
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
guitarman376
10-11-2015 01:47 AM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
Quick Reply: stupid BMR a-arm brace!!!!!
