How much weight should I put in the trunk? - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 01-09-2009, 10:56 AM   #11
buster
put about 150lbs in the trunk. Don't leave it in there all the time. If the roads a dry, take it out or your springs will lose their memory. (In other words, if the car drops 2 inches in the rear, it will stay an inch lower when you take the weight out)
buster is offline   Reply With Quote
Old 01-09-2009, 10:57 AM   #12
ckone0814
I dunno but do me a favor... whatever weight you decide on let me know what it is and how much it lowers the rear... I'm looking for a cheap and easy way to bring it down an inch or so!
ckone0814 is offline   Reply With Quote
Old 01-09-2009, 11:14 AM   #13
buster
Quote:
Just keep adding weight until it drops. 300lbs in a Ranger....my buddy left this in the bed all winter and had to have his springs re-bent in the spring.
Old 01-09-2009, 12:21 PM   #14
ckone0814
Quote:
but what if he wanted to keep it lower, like me? would it mess the car up?
Old 01-09-2009, 12:32 PM   #15
VistaGT
VistaGT's Avatar
I think I have to look into loading the trunk or those tires. The other day it was raining and around a turn in second even with EASY throttle modulation my car did a 360...........lesson: stock tires+4.10s+wet roads and low 30's DO NOT mix
VistaGT is offline   Reply With Quote
Old 01-09-2009, 01:58 PM   #16
Dean Martin
Dean Martin's Avatar
I use 3 bags of water softener salt so 150# and it works well. The salt is easy to handle cause the bags have handles, and I take them in/out as needed...then use the salt in the softener come springtime so I don't have to store something.
Dean Martin is offline   Reply With Quote
Old 01-09-2009, 04:08 PM   #17
rford426
i had 2 50s in the back of mine last snow we got and i was doing good but could have used more
rford426 is offline   Reply With Quote
Old 01-09-2009, 04:42 PM   #18
157dB
Cut & Paste Expert
157dB's Avatar
Salt is the worst thing to store in your trunk.
It causes all sorts of corrosion problems down the road.
Heck why not use some old leaky car batteries for weight?
They are made from lead and are easily moved around.
Sand is the next worst item to have loose in the trunk
during an accident. If you must put something back there
for weight, at least secure it well so it does not become an
interior projectile during a crash.
157dB is offline   Reply With Quote
Old 01-09-2009, 04:50 PM   #19
rford426
my bags were quickcrete bags ha
Old 01-09-2009, 06:50 PM   #20
aircare84
aircare84's Avatar
Quote:
Originally Posted by Tim From Cleveland View Post
How much do these Michelin X-ICE tires cost? Who is a good dealer to get them from?
You running 17" or 18" wheels?
I have 4ea 18" winter tires for sale.
Hankook Ice Bear. Ran them on my GT for 2 winters, 8K on the tires;
400 for the set.
I live in central OH.
I ran 3 60lb Tubesand in my trunk during the winter.
aircare84 is offline   Reply With Quote
2005 Mustang - Transmission rattle and slippage/stuttering AmericanMuscle4.6GT 2005-2014 Mustangs 7 11-10-2015 03:06 PM
95 gt dead fuel pump?? 9550 5.0L (1979-1995) Mustang 10 10-26-2015 06:01 PM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
2005, 2009, car, carry, ford, gt, mustang, put, salt, sandbags, snow, softner, trunk, weight, winter
