Sponsored by:
Sponsored by:
Weird Sound Coming from the Rear.
Old 01-19-2009, 11:46 PM
Texotic
Texotic's Avatar
I thought TSB's were only covered under warranty... they're just instructions to help technicians fix common problems.
Originally Posted by Atlanta_Tider
How many miles are on it? When I worked at Ford we would add some GM friction modifier in the rear ends to cure the clutch pack noise, try it and see if it helps before spending that money!
It has right at 34K miles. But, I do autox it and have done a track day at Texas World Speedway... and I have 285 tires, so I'm sure the bigger contact patch makes the clutch discs slip a lot more than the stock tires would have. I also bought it used with 19K on it, so I don't know how the previous owner treated it.
How much does that friction modifier cost, where do I get it, and how do I put it in? Sounds like it's worth a shot.
Texotic is offline
Old 01-20-2009, 02:21 PM
jmk3
jmk3's Avatar
Try the friction modifier, I used 2 oz. (1/2 bottle) & it cured mine. I used ford friction modfier.
Get it at the dealer or online.
jmk3 is offline
Old 01-20-2009, 02:57 PM
AlloySixxer
AlloySixxer's Avatar
Similar situation for me...I have a brand new 8.8 with 3.73s and at 35-40 mph I can hear a sort of whistling sound coming from the rear. It's only at these speeds and nowhere else. I'm sort of confused since this is a brand new rear end and the gears are installed to spec...
AlloySixxer is offline
Old 01-20-2009, 04:26 PM
tx_zstang
tx_zstang's Avatar
Doesn't really sound like the clutch packs to me with the limited mileage and track usage you've seen. But it is strange that it's now doing it and it wasn't before!
What did they do again at the dealership?
The friction modifier can be gotten for under $5 for a 4 oz bottle, but that usually is needed for turning noises, not highway speed noise! (the clutch packs will slip when you turn or even apply a lot of power to the rear, other times they wont move, or shouldn't).
If you do need a clutch pack rebuild, there are instructions around (I've seen them), and it's a job yes, but can be done.
...but what did they do at the dealership, what did they f-up?
[...Gig'em ]
tx_zstang is offline
Old 01-20-2009, 05:59 PM
Texotic
Texotic's Avatar
Well I've had noises out of the clutch packs for about a year now, but the other day, this sounded kind of like that, but a lot more prominent. There's also been once or twice that I get a short groaning sound at low speeds when I hit the brakes, which shouldn't have anything to do with the clutch packs...
I have no idea what they did at the dealership... I left it there for them to figure out what was wrong with it and picked it up later in the day, payed them $49, and they told me "Yeah, you're right, it's the clutch packs."
I only notice the sound when I'm first speeding up and when I'm making tight, low speed turns. There isn't a peep out of the rear end at highway speeds... at least none I can hear over wind noise, tire noise, rattles, etc.
Texotic is offline
Old 01-20-2009, 06:47 PM
tx_zstang
tx_zstang's Avatar
Ok that helps; the noises at low-speed turns can usually be cured with 4 oz of friction modifier; try that first for at least a week (takes awhile to work its way in real good). If no help, then yeah, I'd say the packs need rebuilding.
If you never had friction modifier in there added then the life of your clutch packs may have been shortened. They made it a TSB to add it for our '05's after the fact, so you probably don't have any in yours.
Are your gears stock/has the rear end cover ever been removed and fluid replaced?
Let us know what you do and find out.
Old 01-20-2009, 07:08 PM
Texotic
Texotic's Avatar
The rear end has never been opened to my knowledge... I was in an accident last year where an axle got bent that needed replacing, so they might have opened it up then. They supposedly have a lifetime warranty on all the work they did, so if they did open it up, I might be able to get them to fix it for free, which would be sweet... I'll give em a call tomorrow.
Texotic is offline
Old 01-20-2009, 10:22 PM
tx_zstang
tx_zstang's Avatar
OK, that's good to know. They had to remove the differential cover to replace the axle. As a result, when fluid was put back in, no friction modifier was likely added. It didnt show up as noisy right away, but proabably over time it did and is now noisy at times.
Sounds like friction modifier is a good bet at this point, IMO.
drfister
05-03-2018 10:38 PM
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
69FB
08-18-2015 08:50 PM
antipeterleague
08-18-2015 01:50 PM
yurizx6r
08-11-2015 07:50 AM
Quick Reply: Weird Sound Coming from the Rear.
