Sponsored by:
Sponsored by:
Gauges killed my car.... HELP!
Old 01-30-2009, 06:59 PM
  #31
Rubrignitz
Rubrignitz's Avatar
Did you hear the whirrrr of the fuel pump purging when you turned the key?
Rubrignitz is offline
Old 01-30-2009, 07:07 PM
  #32
Rubrignitz
Rubrignitz's Avatar
If you didn't hear the whirring sound of the pump powering up it's probably the relay...
shouldn't be expensive to fix whatever the problem.. don't sweat it.
Old 01-30-2009, 07:25 PM
  #33
cobra443
cobra443's Avatar
I heard the noise from the pump. haha I just dont know.
cobra443 is offline
Old 01-30-2009, 10:24 PM
  #34
07 S197
07 S197's Avatar
it would still trigger the starter if your fuel pump wasnt working. If its not even attepting to start its ignition, not fuel. Look at the clutch switch down on the pedals. Looks to see if the switch is being pressing in when you press the clutch. If it is then unplug it and jump the 2 wires with a jumper and see if it works.
07 S197 is offline
Old 01-31-2009, 01:31 AM
  #35
07musclemustang
07musclemustang's Avatar
good idea ^
Also if the fuel pump isnt it if it wont click or turn over then its not fuel its ignition or ignitioncut off (sensor mentioned above, grounds, fuse, ect) sorry dont know anymore ects..
As for getting it going, It will get fixed before you have to leave im sure.. and enjoy it man! before you go and serve!
BIG UPS FOR MILITARY!
07musclemustang is offline
Old 01-31-2009, 09:14 AM
  #36
MEK
MEK's Avatar
This may or may not apply, but I thought I would throw this out there. I recently had what sounds to be a similar problem with my F150 (not the stang), it had something to do with the PATS system. I could turn the key and get power to everything, but when I tried to start it.......nothing, absolutely nothing, no click, nothing. After reading many posts and conversing back and forth on one of the F150 forums, I was ready to give up and have it towed to the dealer. Anyway, one forum member told me to put the key in the ignition, turn it to the "on" position and leave it for about 30 mins.... and then try to start it. I did this, and low and behold, the truck started and I have not had a problem since? Doesn't make sense to me, but it worked? It must have something to do with the PATS system recognizing the key? I spoke with the local Ford mechanic, and he had no idea about this procedure? This may not be your issue, but I thought it couldn't hurt throw it out there.
MEK is offline
Old 01-31-2009, 04:29 PM
  #37
07musclemustang
wow good info!! probably too late for him though...
Is it fixed yet???
Old 01-31-2009, 04:37 PM
  #38
cobra443
cobra443's Avatar
They didnt get a chance to even look at it today.... They said they would be looking at it first thing monday morning. BUT, when I get off work in the morning I will prob. run by the shop and try some of the ideas listed above.
cobra443 is offline
Old 01-31-2009, 05:07 PM
  #39
Rubrignitz
Rubrignitz's Avatar
didn't get a chance to look at it???? maybe they were too busy doing oil changes?? grrrrrr.. I hate some shops.
Old 01-31-2009, 05:17 PM
  #40
cobra443
cobra443's Avatar
yeah, they said they were too busy to inspections at the end of the month! I was like dude I dont have a car right now!! and your doing ppl's inspections because they are lazy wait until the end of the month!
cobra443 is offline
Quick Reply: Gauges killed my car.... HELP!
