Sponsored by:
Sponsored by:
Pinion Gear Removal
Old 11-15-2009, 12:46 PM
Red_Stallion
Red_Stallion's Avatar
Default Pinion Gear Removal
Currently doing a gear install myself (first time!) and it's going really good so far. I'm stuck at trying to get my pinion gear out. A friend did it with a hammer and ended up ruining the shaft of the pinion. I have a friend who is going to be buying the gears off me so this is not an option. I've been using a block of wood and beating on it but no luck budging it so far. I've heard of a thread protector that slips over the threads, should I wait til Monday and get one?
Anyone have any tips?
Red_Stallion is offline
Old 11-15-2009, 02:54 PM
Red_Stallion
Anyone?
Old 11-15-2009, 03:09 PM
hammeron
hammeron's Avatar
the thread protector looks like one of
those threaded rod couplers, maybe 1.5"
to 2" long. not sure of the thread pattern and
whether a local hardware store would have
the size you need.
hammeron is offline
Old 11-15-2009, 03:59 PM
brunobluto
brunobluto's Avatar
The thread protector thing sounds like a good idea if it fits correctly. Or try threading on the old pinion nut untill it is almost flush with the end, And get one of those dead blow hammers. There made out of like hard rubber or some kind of plastic and wont damage the metal nearly as much. They work good. And you will still have to hit it very hard to knock it loose.
brunobluto is offline
Old 11-15-2009, 04:01 PM
CammedMysticCobra
CammedMysticCobra's Avatar
Those can be a bitch
CammedMysticCobra is offline
Old 11-15-2009, 04:20 PM
Red_Stallion
Worried that the old pinion nut might damage the threads...or will I be OK? doing that? Ah well time to get back at er. Thanks!
Old 11-15-2009, 08:40 PM
Diabolical!
Diabolical!'s Avatar
Sorry, but you'll likely find little help here. Gear swaps are the one thing most home mechanics just won't tackle. Good luck though. Let us know how it turns out.
Diabolical! is offline
Old 11-16-2009, 02:02 PM
brunobluto
brunobluto's Avatar
Yea, its possible but might be worth the risk. So did you get it knocked out?
Old 11-16-2009, 03:15 PM
JOHNNY
JOHNNY's Avatar
A brass hammer and punch work or aplie some heat to the outer pinion bearing if you have on of those heater that use magnet and electric they work great but their pricey.
JOHNNY is offline
Old 11-16-2009, 04:30 PM
jbs07stang
jbs07stang's Avatar
Screw the original pinion nut onto the threads of the pinion about half way. Use a brass punch and a hammer to knock out the pinion. The nut is to help as a guide for the punch. The punch should slide through the nut. I hope this helps.
jbs07stang is offline
Quick Reply: Pinion Gear Removal
