Sponsored by:
Sponsored by:
I changed My ATF Today*Pics* (no 56k)
Old 03-08-2009, 07:27 PM
ShadyNinja
ShadyNinja's Avatar
Default I changed My ATF Today*Pics* (no 56k)
Any way I changed my Auto Trans Fluid today
tools needed
jack & 4 jack stands (unless you are ghetto like me, I used 2 sets of ramps, cause I loaned out mine)
T-30 torx bit ( for the fill plug on the drain plug)
7/8 wrench,(for the drain plug), its probably metric but the 7/8 fit good
8mm socket to remove the pan,and the 2 bolts that hold the filter on.
fluid fill adapter (its nothing more than a tapered pipe that is threaded on one end)
here is where you can buy one,
OTC 6604 Transmission Fluid Fill Adapter : Amazon.com : Automotive OTC 6604 Transmission Fluid Fill Adapter : Amazon.com : Automotive
New Fluid,
I chose to use a Quality Synthetic
http://www.amsoil.com/storefront/atf.aspx?zo=1667299
and a fluid pump of some sort.
here is the one I have https://www.amsoil.com/storefront/g2039.aspx?zo=1667299
cost was 11 bucks
a drain pan of some sort,
and a new filter if you choose to change it , the WIX I bought looks EXACTLY like the OEM one, same stampings, weird huh?
1.raise car, be sure its level
wondering about how I got the car up there? see post #11
2. remove drain plug, drain fluid
3 remove pan, there will probably be some fluid in it still so use caution., and try not to hurt the gasket, you will be re using it...
4 clean pan, pay attention to the magnet
5 change filter if you are going to
6 re install pan, you can install the fluid fill tool into the center of the drain plug.
7 get your
and your
ready to fill
pump your fluid in, mine took between 4-5 qts.
when you pull the pump hose off the fill adapter,
"allow the fluid to drain when the fluid comes out as a thin stream or a drip the fluid is at the correct level"
that part is per Ford.
oh here is what the trans looks like with the pan and filter removed
ShadyNinja is offline
Old 03-08-2009, 08:01 PM
Menace
Menace's Avatar
Very cool. I've never done a transmission oil change. I wonder how much different it is for a manual transmission? I wanted to change it a while ago, and now at 33k miles I wonder if that's still too early?
Side note, what's the shelf life on synthetic oil? I still have my Royal Purple Tranny fluid that I never used.
Menace is offline
Old 03-08-2009, 08:19 PM
ShadyNinja
ShadyNinja's Avatar
is it mercon V compatable?
if so it should be ok, and make sure you have @ least 5 qts.
Old 03-08-2009, 08:39 PM
atomicpunk
atomicpunk's Avatar
Why reuse the pan gasket? Didn't one come with the new filter?
atomicpunk is offline
Old 03-08-2009, 08:45 PM
Stoenr
Stoenr's Avatar
Nothin like getting a little oil on the hands!
Stoenr is offline
Old 03-08-2009, 08:48 PM
ShadyNinja
ShadyNinja's Avatar
no
my 2000 mustang has a rubber re useable one with magnets in it to hold it in place while putting the pan back on,
this one is completely different
its a thin rubber gasket and it is in a aluminum shim of some sort...
here is a crummy photo of it...
Old 03-08-2009, 08:51 PM
Xeno
'Dr. X'
Xeno's Avatar
nice write-up
how many miles do you have? (or how many should you have before you change it?)
(btw, i like your wheels; mags are on my to-do list)
Xeno is offline
Old 03-08-2009, 08:57 PM
ShadyNinja
ShadyNinja's Avatar
I'm @ 60k
and because the trans is the single most expensive part on the car to repair,
I should of done it sooner, not sure if the factory stuff is synthetic, but mine is now
Old 03-08-2009, 08:58 PM
Stoenr
Stoenr's Avatar
Howd ya drive up them ramps?
Stoenr is offline
Old 03-08-2009, 09:02 PM
atomicpunk
atomicpunk's Avatar
Ok I see now, it is re-useable. The shim probably helps to keep it from distorting and leaking if you over torque the pan bolts.
Quick Reply: I changed My ATF Today*Pics* (no 56k)
