Sponsored by:
Sponsored by:
control arm relocation brackets??do i need them if
Old 03-18-2009, 02:59 AM
Leos06gtLL
Leos06gtLL's Avatar
Default control arm relocation brackets??do i need them if
control arm relocation brackets??do i need them if get bmr upper and lower adjustable control arms? and if you do run any these bmr products feel free to express your opinion and experiences
thanks guys
LEO
Leos06gtLL is offline
Old 03-18-2009, 03:35 AM
Leos06gtLL
Leos06gtLL's Avatar
car is lowered with eibach pro kit,car is a daily driver
Old 03-18-2009, 06:02 AM
Stkjock
Retired Mod
Stkjock's Avatar
need no, would it be a good idea -YES
it help your traction
IMO you should also get a adj panhard bar to center your axles (if lowered it usually moves)
Stkjock is offline
Old 03-18-2009, 06:27 AM
5SPD07GT
Official Site Sponsor
5SPD07GT's Avatar
i couldnt agree more. i just put bmr lcas on this past weekend without the reloc brackets and its fine but i'll be ordering them here soon. i also have the prokit. do you launch hard very much?
5SPD07GT is offline
Old 03-18-2009, 06:36 AM
Va. Stang
Va. Stang's Avatar
I am running the e- pros plus I have the BMR upper and lowers with the reloc. bracket. And adjustable panhard. I have had no problems and It does make a big difference..... Also not to hard to install.
Va. Stang is offline
Old 03-18-2009, 08:49 PM
bullitt ben
bullitt ben's Avatar
Good question,
I also was wondering
what is the actual function of the relocation brackets?
what are they intended for?
if you have ADJUSTABLE lower control arms do you need them?
bullitt ben is offline
Old 03-18-2009, 09:54 PM
Stkjock
Retired Mod
Stkjock's Avatar
at the track I do, leave at 4700-5000
Originally Posted by bullitt ben
Good question,
They adjust the instant center of the car. The allow the LCA to be angled properly for best traction.
if the car is lowered yes IMO you get a big benefit from them, even with adj LCAs.
Great write up....
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
Stkjock is offline
Old 03-18-2009, 10:58 PM
Jersey Stang
Jersey Stang's Avatar
Good question,
The relocation brackets are only needed if your car is lowered and you do not have adjustable LCA's. LCA's need to remain parallel to the ground. When you lower the car, the LCA's will slope downward, giving you increased wheel hop. By adding relocation brackets, it lowers the wheel end of your LCA, making them parallel again. If you have adjustable lower control arms, you won't need relocation brackets. Also, most people will agree the best setup for a lowered car is non-adjustble LCA's with relocation bracket AND an adjustable UCA to adjust pinion angle.
Jersey Stang is offline
Old 03-19-2009, 02:43 AM
Leos06gtLL
Leos06gtLL's Avatar
i have a J&M adj rod end panhard bar and the steeda brace
yeah i go to the track every once in a while but, i want to get my 60 ft times lower i am at 1.8 right know
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: control arm relocation brackets??do i need them if
