Sponsored by:
Sponsored by:
GT500 chin spoiler install question
Old 03-31-2009, 09:09 PM
Branomano06GT
Branomano06GT's Avatar
Not really I think it would look really cool..... much like the Saleen Extreme Diffuser.... just my 2 cents...
Branomano06GT is offline
Old 04-01-2009, 06:56 AM
05 Mustang
05 Mustang's Avatar
Originally Posted by Xeno
i don't know if it would help any, but i cut off part of the top of the raised middle section of the splitter and mine fits near perfect now; there is still a little bit of a sag in the same area you are talking about, but not enough to cause concern
how high is it screwed in on the inner fender well? it almost looks like you need to raise it higher (if that makes sense)
I was actually thinking the same thing when I saw the pictures...you shouldn't need any type of molding to hide the gap. You should be able to fit the GT500 chin spoiler right up against the bottom of the GT bumper.
05 Mustang is offline
Old 04-01-2009, 08:39 AM
antonio1988
antonio1988's Avatar
Originally Posted by 05 Mustang
I've personally installed 2 GT500 chin spoilers and they have always fit flush under the GT bumper. The only thing that I had to do was add (2) additional screws/lag bolts (1 on each side) under the chin spoiler and into the bottom of the bumper to draw the chin spoiler up, so it didn't look like it was sagging.
below is the picture I marked up for another member...
05 mustang taught me to put mine on, but for the sides where he circled in red, I drilled through the bottom and through the bumper and installed a thick screw and tightened it up and then put JB Weld on it and mine sits high and tight
antonio1988 is offline
Old 04-01-2009, 09:25 AM
Stealth
Stealth's Avatar
In the inner fender well the top screw matches the top screw already there. (if that made any sense)
I don't understand it either.... I'll take pics of the fender well if I remember when I get home.
Stealth is offline
Old 04-02-2009, 04:42 PM
Stealth
Stealth's Avatar
Update.
I installed the molding today, and while it isn't perfect, I'm satisfied with it and it looks a lot better than it did.
Attached Thumbnails GT500 chin spoiler install question-0402091703.jpg   GT500 chin spoiler install question-0402091703a.jpg   GT500 chin spoiler install question-0402091704.jpg   GT500 chin spoiler install question-0402091704a.jpg   GT500 chin spoiler install question-0402091705.jpg
Stealth is offline
Old 04-02-2009, 05:49 PM
Xeno
'Dr. X'
Xeno's Avatar
Originally Posted by Stealth
Update.
huh... that looks a whole lot better than what i thought it would. how exactly did you put the molding on (i may do the same thing to cover my gap )?
Xeno is offline
Old 04-02-2009, 07:14 PM
Stealth
Stealth's Avatar
I pretty much just stuck it in there and screwed through the chin spoiler, through the rubber, and into the bumper. To make for a clean fit at the ends of the bumper (by the wheel wells), I did have to cut the rubber at an angle.
Stealth is offline
Old 04-02-2009, 08:15 PM
05 Mustang
05 Mustang's Avatar
loooks good stealth
svastano
25
07-16-2016 01:20 PM
JonnyBlazeGT
11-03-2015 01:10 AM
carid
08-25-2015 08:17 AM
bikerdoc
08-25-2015 06:46 AM
StangMuscle
08-12-2015 07:27 AM
Quick Reply: GT500 chin spoiler install question
