I just ordered 18X10 rims for the back and 18X9 rims for the front. I also ordered 255 tires for the front and 285 tires for the rear. I heard you shouldn't mix rim sizes, but I wanted a staggered look. Will this setup be fine?
From a tire rotation standpoint, you don't want much if any difference in tire OD so not to confuse the ABS and TCS. As far as width, it may depend on if you're lowered or not. I have 275's all the way around on a stock suspension and there's enough room to fit a small child in my wheel well. Staggering 255's up front and 285's in back should look great. If I recall, didn't the Shelbys come with 255/275's?
No rotations, but otherwise its a go! Many are running that setup, including yours truly. Lowered on the pro kit.
