Sponsored by:
Sponsored by:
how much hp can a 05-09 mustang gt engine handle
Old 04-17-2009, 08:03 PM
Drag5.0mustang
Drag5.0mustang's Avatar
Location: Parrish,Brandenton,Tampa,Florida,Gratiot Michigan
Default how much hp can a 05-09 mustang gt engine handle
im really curious on how much the stock 4.6 3v motor can handle safely
and could you maybe also tell me how much the trans can take and the drive shaft and the 8.8 rear end.
thanks ever one for looking and posting!!
Drag5.0mustang is offline
Old 04-17-2009, 08:11 PM
moosestang
moosestang's Avatar
500 or a little over for the motor. The stock manual has handled over that, but not the clutch. You'll need a new motor and trans before a new rear end, so I wouldn't worry about it.
You said safe and that's my safe number. That should equate to 430-460rwhp on a manual car.
moosestang is offline
Old 04-17-2009, 08:16 PM
Flatline1980
Flatline1980's Avatar
how long would the stock motor hold up with the ROUSHcharger® R2300 Kit without forgeing the internals??
Flatline1980 is offline
Old 04-17-2009, 08:18 PM
shanec
shanec's Avatar
See page 2 here for max ratings (according to Kenne Bell) on various parts of our car
http://www.kennebell.net/techinfo/fo...gtTechTips.pdf
shanec is offline
Old 04-17-2009, 08:19 PM
SirKnightTG
SirKnightTG's Avatar
Is that the Roush TVS blower? If so I'd say not long. It comes with a pulley that makes way too much boost for a stock engine. Apparently there's no bigger pulleys since the solution people come up with is to add an under-drive pulley to lower the boost.
If the Roush blower you're talking about is not the new TVS, then ignore what I just said.
SirKnightTG is offline
Old 04-17-2009, 08:21 PM
Flatline1980
yeap, its the TVS.. forgot to post it up.. my bad.. lol.. i was just wondering..
Old 04-17-2009, 08:27 PM
Stkjock
Retired Mod
Stkjock's Avatar
450 is the generally accepted level for the internals
Stkjock is offline
Old 04-17-2009, 08:35 PM
jz
jz's Avatar
That was some pretty interesting reading. Thanks for posting.
jz is offline
Old 04-17-2009, 10:29 PM
Black GT
Black GT's Avatar
According to this info the stock clutch is good for more HP than the engine (stock engine 525 HP & stock clutch 535 HP).
If the stock clutch is good for 535 HP why are people here reporting the clutch is the weak link and are replacing it with less HP and/or saying eventually if you go FI you'll have to replace it, while their engines are going strong?
Is it the way people drive? Are they slipping the clutch? I've been wondering if I'll have to replace mine in the future, but so far my stock clutch has no problems holding up.
Black GT is offline
Old 04-17-2009, 10:54 PM
AmericanSpeed
AmericanSpeed's Avatar
Clutch is effected by how your car is hooking up. Sure the stocker will be fine when you are on street tires since the tires are going to spin before you over power the clutch. Starting burnouts in 2nd gear also heats the clutch up a lot before drag strip runs, so this can cause it to temporarily slip on the run.
AmericanSpeed is offline
Quick Reply: how much hp can a 05-09 mustang gt engine handle
