Sponsored by:
Sponsored by:
what kinda work is needed to get these to fit?
Old 05-05-2009, 02:40 AM
Red Beast
Red Beast's Avatar
Default what kinda work is needed to get these to fit?
i saw this on another shelby forum, he did not say how he got there to fit, but they are fr500's 12" with 335/30ZR18 tires. how the hell did he make this work? lol
Red Beast is offline
Old 05-05-2009, 05:02 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Good question Red but I made it so the pic shows....sweet stance on that beast!
mygt500 is offline
Old 05-05-2009, 05:15 AM
Stkjock
Retired Mod
Stkjock's Avatar
probably with a sway bar relocation kit at the bare minimum
Stkjock is offline
Old 05-05-2009, 09:43 AM
1morepart
1morepart's Avatar
don't know, but damnnnnn it looks good!
1morepart is offline
Old 05-05-2009, 12:02 PM
one eyed willy
one eyed willy's Avatar
those are about 1 inch wider than my 305/35/20, i think they would fit, if not you may have to get out the BFH.
one eyed willy is offline
Old 05-05-2009, 01:52 PM
Allstar
Allstar's Avatar
wow i would so wait on my rims n tires to fit these fat basteds on there. how do you manage that one??
Allstar is offline
Old 05-05-2009, 02:02 PM
chain1
chain1's Avatar
Seems a bit like overkill unless you're running 600+ hp. Unless you need them that wide for the traction, they are only going to slow you down....
chain1 is offline
Old 05-05-2009, 02:28 PM
WYO07GT
WYO07GT's Avatar
Overkill or not, it probably took some doin to get that much rubber under there.
WYO07GT is offline
Old 05-05-2009, 02:30 PM
foolio2k4
foolio2k4's Avatar
spacers?
foolio2k4 is offline
Old 05-05-2009, 03:08 PM
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
There is a couple of things that were done. First you need to send your rims to http://www.weldcraftwheels.com to widen them because those dont come in 12" rears. Then there is a special fix on the rear that Shelby SuperSnake owners are doing to fit big rubber out back to hook up all that power.
Here is the clip from another Shelby forum that might help. A little price but this is how it was done on a SuperSnake so if you have spent 100k already a little more wont hurt I guess:
****"New product for all SuperSnake owners who want to put wider rubber and still want to use the stock SuperSnake wheels...you don't need 11" wheels.... all you need is a stock SS axle cut down 1/2" on both ends. Working with Gateway Classic Mustang and Moser we managed to produce a duplicate SS axle with all the SS upgrades that looks totally stock. The tires fit right up under the opening just like stock! Worked a deal for a discount for the first 25 people who want one.
Price for the replacement axle assy is $1990 plus shipping....I live in St. Louis and frt was only $100.....
Includes all the Motorcraft lubricants/additive(shipped separately)
Ford Racing 3.73 gears
Special price for the first 25 units sold $1890
Contact Gateway Classic Mustang
Jason Childress
Toll Free:
1-800-396-6488
GatewayClassicMustang
The 305's don't rub or hit anymore...I wanted the wider rubber but wanted to keep using the special SS wheels...I have no idea what the cost of the new 11" Alcoa's with the proper offset are going to cost but this will probably be cheaper......If you want them to convert your existing axle the savings is $600. I decided to keep my original one for sentimental value. Gateway will even install it for $200 if your in the area. They are going to be in Birmingham if you need them to bring one...I've attached some before and after pictures. Please direct all technical questions to Jason at the provided number... "****
Also take into consideration that the Alcoas in 10" have a rather low offset (37.86mm). If you get a little higher offset as your base on a 10" wheel, like a 45mm offset, you could probably squeeze the 335's.
Here are some pix---
MELLOWYELLOW06 is offline
Quick Reply: what kinda work is needed to get these to fit?
