Can i run 12 seconds ?
i got stock 06 mustang gt 5 speed i want to know what it would take to get it to run low 12 or high 11 seconds without blowing the engine if it possible what the best time i can get it to run while keeping the engine alive for a long time lol thanks write a list of parts if u can.
Saleen S/C 3.4 pulley
39lb injectors
Custom dyno tune
FRPP 4.10's
SLP Line lock
BMR lca's with relocation brackets
Steeda CAI
Pro 5.0 shifter
CHE k-member brace with torque limiters
Prothane motor mounts
Mcleod RST Twin disc clutch
Mcleod Billet steel flywheel
AFCO heat exchanger
Mickey Thompson ET Streets 275/40/17's
Diablo Maifia
SCT Xcal II
One extremely high limit and very maxed out Visa
I am on my 3rd clutch, and 4th rear end
Parts in garage: Steeda Adjustable Upper control arm, and M&H 275/50/17 DR's mounted taking them to the track tomorrow uca will be getting installed either thursday or friday. There may be a couple of things I have forgotten about.
The thing to remember is to try and spend the money once, its better to spend a little extra now than to have to repeat the process (like my clutch, rearend was fixed under warranty so I don't count that), also traction will become a very big issue especially on your street tires, I am at the point will the tires will break loose in 3rd when getting on the freeway.
Also be prepared for a lot of downtime. My ride at one point was down for 4 out of the first 6 months last year trying to fix clutch issues, tune issues, and my Xcal took a **** and earsed the tune in my car but would not reload the tune back in it.
But it is extremely fun to drive when the weather is nice, no rain driving, no driving when its extremely hot (at least in traffic), and I don't go to the track if its over 96 degree out side. Forgot got 38k on the car, had the S/C installed at 18k no engine problems or trans problems (except for the stupid specs II + clutch Damn I'm still mad about that.)
here is an article for how to get into mid 12s
http://www.musclemustangfastfords.co...rts/index.html
throw on a few more simple mods than they did and low 12s are possible emmisions and passing inspection in CA will probably be the hardest part for you. you can get into the upper 11s n/a but it takes quite a bit of money and im not sure you could pass emmisions with the parts you would need. (Heads, Extreme cams, and LT header exhaust might make you fail)
with the mods in my sig I ran consistant 12.70s...bamachips 93 Race Tune, JLT CAI, Mickey Thompson E/T Streets Bias Ply, and an O/R X-pipe...pretty minimal if you ask me...12's arent hard to reach...I'm hoping to get low 12s to high 11s with my new mods...cams, gears, LTs
zanemoseley
09-06-2015 12:58 PM
