My 305/35/18 drag radials are worn out completely. It's time for new tires. I don't want drag radials again simply because they don't last and the rocks that hit your wheel wells are so effing annoying. I was planning on going with 285's on my rear. In the front I'm running a pair of Nitto NT555R 275/40/18. I want to know what you guys think I should go with.
in addition to what they said above I would go at least 295 in back since the car has staggered tire sizes and they cant be rotated anyway....hell they make a 305 that is NOT a DR and that is what should replace your back tires...JMO
That's true. Who makes a tire that is not a DR? The DR is just so annoying when driving on side streets (all around my little town of Davie, FL). All you hear is all the rocks hitting your wheel wells and it just sounds so bad.
Do you guys recommend I go with Nitto's for the back since that's what I'm running upfront or do you recommend another brand. And for the record I'm putting down about 315 RWTQ so let's keep that in mind as well.
