Sponsored by:
Sponsored by:
blown starter relay
Old 05-17-2009, 09:27 AM
usc49erfan
usc49erfan's Avatar
Default blown starter relay
i have recently had the problem of blowing relays, the cube shaped fuse in the engine bay. the battery is fine, lights etc. all work, but the engine will not turn over, i know it's not the starter, but the last time i had this problem i switched the horn relay with the starter relay and it worked, problem happened yesterday, but this time not such an easy fix. i was wondering what the problem is and why this is happening?
thanks
usc49erfan is offline
Old 09-10-2009, 01:28 PM
1MEANSNAKE
1MEANSNAKE's Avatar
thanks
Hi, did you ever figure this out?
My fan relay keeps blowing and It's causing the car to overheat and spew antifreeze everywhere
1MEANSNAKE is offline
Old 09-19-2009, 06:54 PM
usc49erfan
usc49erfan's Avatar
finally got it, the problem was the starter was grounded which was blowing the fuse
Old 09-19-2009, 09:24 PM
hammeron
hammeron's Avatar
1MEANSNAKE, if you are still under
warranty, you might want to consider
taking it in for this. i don't think it's
serious, but if it's covered it's covered.
hammeron is offline
Dathan
10-05-2015 05:52 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
logan409
09-26-2015 07:43 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: blown starter relay
