Sponsored by:
Sponsored by:
Could i bore out my engine to get a higher liter on my V6?
Old 05-22-2009, 07:58 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Yep, cheapest way is to supercharge it...
Since there aren't heads or cams worth a sh#t from the aftermarket people.
Problem is, with a V6, rear ends and primitive manual trannies don't take too kindly the found power.
pascal is offline
Old 05-22-2009, 11:26 AM
tx_zstang
tx_zstang's Avatar
People do swap v8s into v6s. yeah it's a lot of work. And yes, the entire drivetrain needs to be considered, too (tranny, driveshaft, rear end).
But it can be done.
As far as boring out the 4.0, there's been some articles on it, but it's not really a viable thing to do. The cylinder walls aren't that thick, if I recall, so you can't bore out much at all. By the time you do it all, you haven't gained much. Of course if you build up the internals at the same time, then you could slap a blower on, up the boost, and have plenty of power. Of course, dropping in a V8 would be simpler.
Having a V6 with a blower is a fun alternative. Yeah, you still should or will need to upgrade the rear end and possibly tranny. But much simpler than putting in a v8.
But do what you wish; remember it's YOUR CAR!
tx_zstang is offline
Old 05-22-2009, 12:59 PM
drfister
drfister's Avatar
Read some of the articles/ info here if you have not already done so...
http://www.supersixmotorsports.com/
drfister is offline
Old 05-22-2009, 02:47 PM
cobrakiller347
cobrakiller347's Avatar
i heard the v6 suspension really sucks compared to the gt....
cobrakiller347 is offline
Old 05-22-2009, 04:11 PM
pascal
pascal's Avatar
Smaller swaybar up front and none at back (except pony).
I think the shocks are the same but I'll have to double check that.
Also, smaller front brakes...
pascal is offline
Old 05-22-2009, 04:17 PM
cobrakiller347
i heard that the handling on those is worse than in the rangers... im not sure if that was the new edge v6's or the s197s
Old 05-22-2009, 04:23 PM
pascal
pascal's Avatar
Come on now...
A ranger is much higher and body roll like there's no tomorrow...
A new edge V6 will still handle better.
pascal is offline
Old 05-22-2009, 04:52 PM
cummins cowboy
cummins cowboy's Avatar
v6 cars are like auto trannies in mustangs, why in the WORLD would anyone buy one equipped like that. when I was in highschool my dad bought an 89 mustang with a 4 banger, I used to dream of it being a v8 every day
cummins cowboy is offline
Old 05-22-2009, 05:29 PM
izzyocon
izzyocon's Avatar
you could bore out your engine. but when you order your pistons and and other parts, everything is gonna come in a set of 8
izzyocon is offline
Old 05-22-2009, 09:25 PM
MrSandman
MrSandman's Avatar
A SC or Turbo will be cheaper.. and faster.
MrSandman is offline
Quick Reply: Could i bore out my engine to get a higher liter on my V6?
