Help !!!!!
These cams are NOT too aggresive for the stock valve springs. I agree with moosestang, Get a lawyer.
Good luck.
Its hard to say. Go in there with the specs for stock, hot rod (which was designed by the same ford engineers that designed the stock cams), and your thumpr. Try to reason with them by letting them know that there are tons of people running cams with more lift than what your thumpr had, with no problems. Try to work out a deal with them (although they should be taking care of everything to get your car back to the way you left it to them).
This could be a freak accident, but more than likely a bad install job. What cylinder was it? Some cylinders are harder to work on b/c of the firewall and little room in the engine bay. They may have not gotten a cam follower back on correctly which resulted in a broken spring.
If the shop thinks that is the case, then they should not have done the job without replacing the springs. They are supposed to be the "experts." From what you have written, it seems to me that fixing the problem is the responsibility of the shop.
Im giving them the benefit of the doubt. They said they've done a few of these cams already in which they replaced the springs, rockers, and lifters. They even showed me a copy of their dyno sheets which were pretty impressive. I think I just had really bad luck. I guess thats what I get for trying to cut corners.
