Sponsored by:
Sponsored by:
Shorty Antenna from Pep Boys?
Old 06-03-2009, 01:44 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Default Shorty Antenna from Pep Boys?
I was calling around trying to find where I might find a shorty antenna without having to order one.
I called pep boys and they said they had short universal antennas.
Has anyone used these or know if they would work for us?
Blacksmoke is offline
Old 06-03-2009, 02:01 PM
degeze
degeze's Avatar
Just cut your factory one and stick the ball back on top, it's free .
degeze is offline
Old 06-03-2009, 02:05 PM
Orion_240
Orion_240's Avatar
Can you explain how you take off the ball and "stick it back on top?
Orion_240 is offline
Old 06-03-2009, 02:14 PM
05slpGT
05slpGT's Avatar
Where in Texas are you? If your in Houston we have some in stock you can pick up.
05slpGT is offline
Old 06-03-2009, 02:19 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Sorrry Im a LONG ways from Houston hehe
Old 06-03-2009, 02:21 PM
degeze
degeze's Avatar
Use plyers but wrap the ball with a towel so you don't scratch it. Cut the antenna to your desired length (8", 14"), then put a drop of adhesive (I used super glue) on the inside of the ball and push it back on top. Push on the ball hard to make sure it on...that's it.
degeze is offline
Old 06-03-2009, 02:57 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
What did you use to cut the antenna?
Old 06-03-2009, 03:29 PM
SikO7GT
SikO7GT's Avatar
You could use a dremel to cut it and sandpaper to smooth down the cut!
After that superglue it on top and spray paint it black for a nice finish!!
Well thats what i plan on doing but i need to buy a dremel first!!
SikO7GT is offline
Old 06-03-2009, 03:47 PM
southernmustangparts
Former Sponsor
southernmustangparts's Avatar
If you decide to order one we have sold a bunch of the Lund shorty antennas
5.5in and 9in
Mustang shorty Antenna
Thanks
Ken
southernmustangparts is offline
Old 06-03-2009, 05:28 PM
degeze
degeze's Avatar
I used a Dremel but if you don't have one a hand saw could work. You will need to use sand paper to taper the end for the ball because the original antenna is wider at the bottom than at the top. It's very simple though.
degeze is offline
Quick Reply: Shorty Antenna from Pep Boys?
