Sponsored by:
Sponsored by:
Car pulls a little to the right...worth worrying about?
Old 06-16-2009, 09:40 PM
ThaiCobra
ThaiCobra's Avatar
Default Car pulls a little to the right...worth worrying about?
so if i am driving on a flat road, and i let go of the wheel, the car drifts to the right, and after about 400/500 yards I would be off the road if I don't grab the wheel and correct.
Is this an alignment issue? tire balancing issue?
Is this even worth worrying about/bringing to a shop? I've heard from a few people that no matter what you do, a car will always drift a little to the right or left...that it's a losing battle
ThaiCobra is offline
Old 06-16-2009, 09:59 PM
candymanjl
candymanjl's Avatar
is the road perfectly flat? most roads are crowned to the outsides to keep water from building up on the road when it rains. that crown will usually be enough to have the car pull to the outside a little. that could be it and also check you tire pressures.
candymanjl is offline
Old 06-16-2009, 10:14 PM
ThaiCobra
ThaiCobra's Avatar
tire pressure even in all 4 tires.
Old 06-16-2009, 10:21 PM
Charlie321
Charlie321's Avatar
Alignment.
Charlie321 is offline
Old 06-16-2009, 10:24 PM
5SPD07GT
Official Site Sponsor
5SPD07GT's Avatar
my thoughts exactly.
5SPD07GT is offline
Old 06-16-2009, 10:49 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Try to drive on the left side of the road and see if the car pulls to the left, lol.
A good test is a mall parking lot at night...
It's most likely flat and you should have enough room to do it, so you can see if the car really pulls.
On most roads, you have to expect a slight right pull for reasons already stated by candymanjl though.
pascal is offline
Old 06-16-2009, 11:58 PM
Art161
Art161's Avatar
I agree. I think the best way to do this is to take your hands off the steering wheel. Let's assume the car pulls to the right. Then turn around and go on the same path, but in the opposite direction. It the car still pulls to the right, you have eliminated the road surface as a cause of the pulling.
Art161 is offline
Old 06-17-2009, 11:42 AM
illini4
illini4's Avatar
The most likely causes of pulling to one side are alignment (caster) or a bad tire. You can determine if it's a tire by criss-crossing the front tires and driving to see if the pull is now in the opposite direction. If tires aren't the problem, have an alignment done. Most modern cars don't have caster adjustment, but kits or work-arounds are usually available.
illini4 is offline
djbigskrilla
09-20-2022 01:04 AM
mirandaandjimmy
11-16-2015 08:51 AM
algregory
09-06-2015 05:52 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car pulls a little to the right...worth worrying about?
