FI guys
i had a separator, then changed to triple breathers. 1 on each valve cover and 1 on the oil filler cap. i was getting blow by out the passenger side, but i switched oil from 5w20 to 5w30 and now no blow by.
doogie, it's been so long i had to
look it up.....the 5122
https://mustangforums.com/forum/4-6l...modaddict.html
If you are running boost, you should be running an air/oil separator or "catch can". It's cheap insurance. If you need confirmation, pull your intake off at the throttle body and run your finger along the edge of the blades. I run a moroso setup (simply because it was a few bucks cheaper than the Stef's version).
