manual . shifting question
#23
How would you best describe it?:
A: Is moving the actual shifter not smooth? For example is your arm physically moving the shifter difficult?
Or
B. is the car itself jumpy when you shift? Like the car "jolts" when you shift?
If its A, then the K brace and Motor Mounts are supposed to help that issue.
If its B, its just you, and you just need more practice.
#24
no i know its me and i need some more practice i was just asking what i was doing wrong.. like why would it not be as smooth ... am i not shifting quick enough.. am i letting off the clutch to slow to fast. not adding enough gas? like thats what i was asking .. what can i do 2 make it more smoother.
#25
Your probably releasing the clutch to fast while rpm's are low which is causing the car to jolt or even shake a little!!
I suggest releasing the clutch slower and practice until you find the sweet spot of the clutch!!
When i'm cruising i usually just shift at 2k rpm idk what rpm your shifting at while cruising??
#26
nah im def not doing that im saying if im getting on the car like in 1st at like 5k rpms and then i shift into 2nd its not a smooth like if i was shifting from 3-4 at 5k rpms... idk if thats just normal tho bc im going fast
#27
idk my friend said im good but hes been driving manuals for like 7 years so his shifts are pretty much perfect... he said that i shift a little slow...so i guess i gotta practice on that... so i figured maybe the rpms were dropping to quick since im at 5k rpms and then they drop a little by the time i get in 2nd gear so the car doesnt really smoothly going into 2nd if that makes sense
#28
Most of that is just practice and finesse. Just keep working on it and it will come with time.
Personally, when I'm driving like that I'm usually too worried about smoothness anyways. I only worry about that when I'm just cruising and/or have someone else in the car with me.
#29
