Sponsored by:
Sponsored by:
need help with pass side window...the AUTO part of it stopped working.
Old 06-21-2009, 05:17 AM
maxpain
maxpain's Avatar
Default need help with pass side window...the AUTO part of it stopped working.
like the title sasy...I tryed to openen it.....clicked on the drivers door button and the window just went down a little bit....I tought I didn' pressed it hard enough and tryed again...but still the same ****.....I also tryed the button on the pass side door and still the same ****...what could it be....fuse,bad switch...something int ecu maybe...
maxpain is offline
Old 06-21-2009, 05:56 AM
moburto07GT
moburto07GT's Avatar
There is a way to reset the auto feature by, rolling the window all the way down and holding the switch for approx 3-5 seconds, then roll it up and hold the switch for again 3-5 seconds. It is in the manual for your car i just cant remember where and i don't have access to mine (at work). If that doesn't work then it could possibly be a fuse or a bad window switch.
moburto07GT is offline
Old 06-21-2009, 10:13 AM
eddypython
eddypython's Avatar
yah. what he said. use the search function of the forums also. you will find it. there are N number of threads on it.. It happened to me too like 4-5 times and I just put the key on " on " and roll up the windows, hold it for like 4-5 seconds, then turn the key " off " then " on " again and roll down the windows, and hold the buttons for like 4-5 seconds. then " off " and " on " again and it's reset and fixed.
eddypython is offline
djbigskrilla
09-20-2022 01:04 AM
Hogquad
08-23-2015 05:26 AM
jpplaw
08-22-2015 09:29 PM
kdryan
08-21-2015 04:01 PM
chain
08-17-2015 08:52 AM
Quick Reply: need help with pass side window...the AUTO part of it stopped working.
