Sponsored by:
Sponsored by:
Can't put gas in the tank on 08 GT?
Old 06-22-2009, 04:44 PM
  #21
Orion_240
Orion_240's Avatar
There are about 2 dozen+ threads on this.
Try the usual fixes mentioned.
You also might pay attention to what kind of nozzle the gas station uses. Here (CA) they seem to replace them with different styles all the time. The latest ones were supposed to trap gas fumes better, but that would only make this issue with my 2005 GT worse. Turning the nozzle wouldn't work as the new design made it to wide and it would shut itself off.
It would be nice if people could post photos of the good and bad nozzles. The old style, like the kind they had in Nevada and Arizona seemed to work a lot better.
Orion_240 is offline
Old 07-01-2009, 04:01 PM
  #22
CandyRedGT
CandyRedGT's Avatar
Originally Posted by PistolPez73
I have the problem as well on my '07. I find it varies depending on which gas station I visit.....Some gas stations I have no problems at all while others I have major issues with.
ALL gas pumps do it on my car?? Dealership replaced the COMPLETE evap system today. STILL does the same crap???? The 08 has a totally different design filler neck and tank from 05-07 also. Filler goes thru the frame..not under it. Actually seems worse? Also....turning the nozzle upside down does NOT help /seems worse?
CandyRedGT is offline
Old 07-01-2009, 04:02 PM
  #23
CandyRedGT
CandyRedGT's Avatar
Originally Posted by OhioState87
If I put the nozzle in too far, it does this. If I pull it out just a tad, it works just fine. Next time, try not putting it in as far as it can go; keep pulling it further and further out until it'll work.
Tried all of that/even upside down.
Old 07-01-2009, 04:04 PM
  #24
CandyRedGT
CandyRedGT's Avatar
Originally Posted by Xeno
there is a tsb on this issue for 05-06 model years, but i suppose the same thing could happen to a later model year; it was common enough that i would have assumed the dealers had heard about this problem...
i have an 05 and had this problem too. went to the dealer, gave them the tsb number (they also questioned me how i knew about the tsbs too ... you'd think they'd know the internet is a vast and wonderful resource), they replaced the fuel tank, and now everything is working fine.
anyway, i attached the tsb for the 05 models, but the 'tsb 06-3-13' number hotdogn mentioned is an updated version of the 05 one. good luck
Thanks but the 08 has a different gastank/filler neck setup.
Old 07-01-2009, 04:42 PM
  #25
AMoRT
AMoRT's Avatar
Originally Posted by rdsx18
I'm happy I haven't had this problem, but I have heard that if you spin the pump nozzle upside down then it works good. It's worth a shot if you have the problem.
+1 upside down has never failed for me
AMoRT is offline
Old 07-01-2009, 06:24 PM
  #26
5T4NG
5T4NG's Avatar
mine only does it at Chevron stations...
5T4NG is offline
Old 07-02-2009, 09:51 AM
  #27
157dB
Cut & Paste Expert
157dB's Avatar
Its a procedure and if you dont follow
one step correctly its dribble time for you.
Nozzle in filler but not too far.
Hold nozzle at the 5 o clock position.
Start slowly to get the flow going and
then full bore until its full.
If that dont work, try a few of these....
Stand on head and pray to the Ford gods.
Bad mouth Ford every chance you get.
Go flip off salesman and service manager.
Write your congressman and Ford directly.
Hold breath until you get a response.
Hope you dont die first.
Replace the 1" rollercoaster molded downtube with a bigger one.
Replace the EVAP canister vent filter.
Pretend to buy new Ford and vent to them about the situation.
DEMAND to see every TSB concerning you vehicle.
157dB is offline
Old 07-02-2009, 10:05 AM
  #28
Texotic
Texotic's Avatar
I didn't feel like reading all the responses, but my '05 does it occasionally. Sometimes, on the same pump, but different weeks, it will work or not work. Flipping it upside down works everytime. I get get weird looks, but it doesn't take me 15 minutes to fill up.
Texotic is offline
Old 07-02-2009, 11:21 AM
  #29
wingman75
wingman75's Avatar
In three years mine has done it only about 3 or 4 times. When it does I rotate the nozzle 90 degrees or more to the right and all is well.
wingman75 is offline
Old 07-05-2009, 05:08 PM
  #30
fordchuck
fordchuck's Avatar
i just don't set the automatic pump at the highest setting and haven't had a problem since.
fordchuck is offline
Quick Reply: Can't put gas in the tank on 08 GT?
