4.10 gears - won't spin
#21
I have 275/40/18 out back, high performance summer time. I can always chirp into 2nd but if I get it just right I will smoke the tires and chirp into third. Maybe there is something else wrong with the car? Are you at a higher elevation?
#22
I can chirp going into 2nd. Just can't stab it from a roll in first and get them to break loose.
I am at 3200' elevation and often times the overall DA is well over 4000'. Hard to say for sure whether that is making a big enough difference or not to really be a factor here.
Regardless the car has no CEL displayed and purrs like a kitten. If there is a problem with the car it's certainly not very obvious.
#23
Chevy's LS engines shouldn't be much better, relatively speaking. Having 25% - 30% more displacement to work with can cover for a fair amount of low end output being "soft".
Norm
#24
4000 ft elevation shouldn't do much to it. With stock tires though you should have problems keeping traction in 2nd when you hit it hard, you would think.
What RPMs do you shift at when you go from 1st to 2nd?
When I am shifting I usually try to shift around 5500-6000 and when i shift hard enough the back end gets loose.
#25
I shifted into 2nd at 6000rpm. I don't side step the clutch or power shift it. I slip it out, albeit quickly. Still enough to occasionally chirp the tires if I do it just right. But no the car still holds and doesn't bust the back end loose and start floating on me. Leastways it didn't when I tried this last night.
Norm - thanks again for the explanation(s).
#26
I hate when someone says a 'stall converter" that is like saying an 'inch tire' huh. Stall is a function of the converter. like an inch is a function of a tire size. . ie.. 17" tire, 18" tire.. and 3000 rpm stall or a 3500 stall speed converter. There is NO such thing as a 'stall converter. all converters have stall speed. How much is what makes a converter launch harder..
BTW- I can burn the tires on a 1-2 shift with 3.31 gears.. Enough to activate the traction control
Friend of mine tells me it's because I have a manual. And that a stall converter, auto car, is more likely to break the tires loose even from a roll.
"auto you can wot then flash it so it hits the pwoerband alot faster therefor spin tires easier"
Thats what he is telling me. I don't understand the explanation though.
#27
I cant spin the tires from a roll either unless i slip the clutch a little. Like stated in the thread its just not the way the engine and manual transmission is set to do easily. I wouldnt worry. I can when shifting when i want to just as you have stated.
And anyone thinking 4.10s with a manual is to much are pussies! The stories here exaggerate how the car acts. First gear is very short but you can easily manage wheelspin unless you are FI or have an odd tune with to much touchiness.
#28
well, my 4:10's act differently than described by most. i can ignite the tires from a 2500 roll and polish second and chirp third, easily.....from a dig....major burn-outs.
i run a 255/45/18 kdw2
my 2 cents
my 2 cents
#30
Yeah I think some of the comparisons being thrown into the thread, though welcome, are a bit short on the details. Tire/wheel size and transmission are factors. Without that information it's hard to draw conclusions.
