Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2014 Mustangs
Sign in using an external account
Register Forgot Password?
Search
2005 - 2014 Mustangs Discussions on the latest S197 model Mustangs from Ford.
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Shaker 500 audio noise
Old 09-14-2011, 08:40 AM   #241
MyKonaBlues
MyKonaBlues's Avatar
Vehicle: 2010 Ford Mustang GT
Thanks Natasha. I love the car and the service people I work with. I look forward to continuing my support for my local dealerships.
MyKonaBlues is offline   Reply With Quote
Old 09-14-2011, 11:45 AM   #242
FordService
Official Ford Rep
FordService's Avatar
Vehicle: Mustangs
facebook.com/FordMustang @FordService
Quote:
Thank you very much for your support of the dealership! It is very appreciated.
~Natasha
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @FordMustang @Ford
f: facebook.com/FordMustang facebook.com/Ford
FordService is offline   Reply With Quote
Old 09-28-2011, 06:36 AM   #243
mbyers
Vehicle: 1964 1/2 and 2011
Quote:
Originally Posted by FordCustomerService View Post
Hi mbyers,
I'm pleased that you had a positive experience with your dealer, and I know that sound can be annoying. Please PM me with your VIN, contact information, mileage, & servicing dealer name/state so I can review your ACM issue.
~Natasha
I just wanted to follow-up, and am posting vs PM.
Since I was bringing in the car again (for oil change & Satellite issues) I re-ran this test before going in. In my garage I can hear it. It is very difficult to hear, and you need good hearing.
When I tune to strong FM station and then turn volume to Zero, I can VERY faintly hear the FM station. It is hard to hear over the white noise. I switched to Sirrus (just press the Sirrus button) and I can still hear the FM. Change volume to 1 and I hear the Sirrus station.
The dealer could not re-create the bleed through, just the white noise. They called the hot-line and they said to test like cars. Of course they have the white noise problem, we all know this is a design issue with the radio. I did sat in parking lot with tech and with the ambient noise couldn't hear the bleed through. At this point I'm just not going to worry about it anymore. I like my dealer too much to make them keep going through this. Ford knows the issue is there and hopefully they will address in feature models.
__________________
1964 1/2 Convertible / Guardsman Blue / D code 289 4V
2011 Coupe / Pony Package / Kona Blue / V6 (ordered 5/18/10, built 6/11, arrived 6/22, delivered 6/25)
mbyers is offline   Reply With Quote
Old 09-28-2011, 07:55 AM   #244
bigbirdwpg
Vehicle: 2012 Mustang GT/CS
My 2012 GT/CS with Shaker 1000 does that too. Kind of annoying.
__________________
2012 Mustang GT/CS Black, glass roof, Shaker 1000, DynoTech drive shaft, 3:73 gears, Steeda CAI, BAMA tune, GT 500 style wheels - black machined.
bigbirdwpg is offline   Reply With Quote
Old 09-28-2011, 01:13 PM   #245
FordService
Official Ford Rep
Vehicle: Mustangs
Hi mbyers,
Your positive feedback on your dealer is appreciated, and I'm sorry they were unable to replicate the bleed through. If it increases, please let them know so they can review.
Quote:
Hi bigbirdwpg,
If your radio noise becomes more of an issue, I suggest visiting your dealer so they can listen and work to silence it. While there, you may want to try out a similarly equipped Mustang to see if it sounds the same.
~Natasha
__________________
FORD SERVICE
p: 800.392.FORD
Old 02-18-2012, 09:00 PM   #246
sbradle4
sbradle4's Avatar
I know this is an old topic, but my 2010 that I just bought has this issue. Ford replaced the entire head unit and the control module. It still has the white noise issue. They will be replacing the amp next week to see if that fixes it. Thank goodness for warranties!
UPDATE* Amp was replaced, still get static in speakers. Ted Russell Ford in Knoxville, TN states the static as "acceptable" wtf???
sbradle4 is offline   Reply With Quote
Old 03-18-2012, 08:04 PM   #247
kr3lc
Exclamation Does a head unit replacement remove the noise?
I've had a 2010 with Shaker 500 just two months and I'm really annoyed by the noise at low to no volume. I do have a nice aftermarket head unit that I removed from a 2005 Mustang that I am thinking of installing into the 2010. I know about the panel, and issues with keeping Sync and steering wheel controls and despite those hurdles I make the change up if it will get rid of this noise. Does replacing the head unit with an aftermarket head unit also replace the ACM, which I think has been pinpointed as the real source of the noise?
kr3lc is offline   Reply With Quote
Old 09-17-2012, 01:33 PM   #248
witchdoc
Vehicle: 11 GT Convert
I have the white noise as well when key is OFF and hiss stays on until the lights turn off.
It is loud enough when driving with all radio nav etc turned off to hear as well.
My 2011 has NAV . bELOW is copy paste from another site on this :I am taking car in tomorrow "for them to look at"
_________________________________________
The head unit IS on, but in a "hidden state".
When you unlock the car the head unit is booted up - this gives it more time to boot up (initialise the sat nav, read the map, get a GPS fix, etc.) - but it displays a blank screen until you turn the ignition on.
Similarly when you turn the ignition off it doesn't actually turn off the head unit, it again goes into this "hidden state" which it only exits when you either lock the car or after around 30 minutes. This is so that it won't have to reboot if it's only a short stop.
The amplifier enable line is (unfortunately) taken active even when the head unit is in this "hidden state" - hence the hiss from the speakers even when the head unit is apparently off.
witchdoc is offline   Reply With Quote
Old 09-18-2012, 06:16 AM   #249
mbyers
witchdoc, that is good information. Finally something that 'makes sense' in explaining what is going on. Still a design flaw, but at least we know what the flaw is :-)
__________________
Old 12-16-2012, 01:35 PM   #250
witchdoc
Ok lousy Christmas present ,as Ford changed "head unit ' Sub woofer amps and all other Ford Tech suggestions and of course ,white noise ,was still there. Oh well, they did try very hard to correct it. Classified as "normal" noise with Shaker and Nav unit. until something in a TSB corrects it. Car now in storage until spring thaw .
Old 12-28-2012, 11:19 PM   #251
MyKonaBlues
Wink
Quote:
I gave up, too many trips to the dealership for this, then rejected further exploration on my Shaker since they found I had installed Polk Audio 5x7's in the factory locations and NO other mods. Sad how Ford thinks the distortion is normal to the Shaker 500 in the Mustang. We also have a 2012 Explorer with the Sony Nav Audio system, and it has great a audio system with NO noise. I recently traded the Mustang for a different needing 4 doors (fear not- NO Chevy/NO Dodge sought) and ended up with a VW GTI. I would have jumped in a Focus ST, but feared the same service woes I did with the Mustang. (sorry guys). The Explorer is keeper though...
Old 12-29-2012, 08:05 AM   #252
mbyers
The root cause is internal to the radio head. Either line filters are not there, are cheap ones, or circuit design flaw. Swaping parts just won't fix this. The radio head needs to have its design fixed and new ones made. With today's electronics it is too hard to jus swap internal parts. Making new head units would cost Ford too much. I would guess they would fis this in the next radio design, but that is probably the 2014.5. We just have to live with it. At least that is what I came to after trying to get it addressed a while back. Just turn up the radio or put on louder mufflers :-)
__________________
Old 04-17-2014, 08:59 AM   #253
Awsm5.4
Vehicle: 2011 Ford GT500
Angry Is anyone still searching this?
Why has this gone cold as of 2012???!!!!
Is there a different forum on this?
Can someone chime in because I cant fathom how this can be considered acceptable in a $70000 car.
A $10000 Saturn doesnt do this???!!!!!!
Awsm5.4 is offline   Reply With Quote
Old 04-17-2014, 11:35 AM   #254
sbradle4
sbradle4's Avatar
I think Ford's "give a damn" ran out on this issue a long time ago. Mine has done it since the day I bought it off the lot. They replaced the head unit and the amplifier... Still does it. Dealership stated it was "acceptable."
__________________
2010 Red Candy Metallic GT
Mods:
3D Carbon Eleanor Grille, Steeda Tuned, FRPP-P Lowering springs, J&M aluminum adjustable panhard bar, Steeda Pro-Action Shocks and Struts, GT500 Strut mounts, 20" Charcoal AMR's, AirRaid CAI, Flowmaster Outlaw axle backs.
Old 04-17-2014, 12:00 PM   #255
Mishri
Mish-ogynist
Mishri's Avatar
Vehicle: 2012 5.0 premuim
I think people that are that picky about their audio should use aftermarket equipment. Some people have some high expectations for a factory stereo system. I think it's better than most any factory system I've heard. If the issue really is the head unit replacing that would seem like a no-brainer, get a new good quality one.
For the record, didn't have any issues with my 07 shaker 500 or my current 2012 shaker 500... everything works great.
edit: read how people are achieving this, engine off in a quiet location with no music and the volume turned on? WOW!! how picky do you have to be to find this? there is an off-button on it. if you aren't listening to it, turn it off. Like i said, if i were this picky I'd just go aftermarket and get good quality stuff.
btw...I have a $5,000 home audio setup that also "has white noise" under these conditions.. LOL! It's because it's sending what signal it is getting to the speakers. (with no audio present that means any electrical noise there is)
To everyone in this thread: It's working as intended.
__________________
Automatic, Steeda CAI, 4.10 gears, Boss Intake, BBR O/R X, Steeda Tune, M&H Drag Radials.
12.6@112mph (DA corrected 11.7@119mph)
Quote:
Originally Posted by ImpOnFire View Post
mishri created the universe
Mishri is offline   Reply With Quote
Old 04-17-2014, 12:02 PM   #256
Rudolph Hucker
Rudolph Hucker's Avatar
Vehicle: 2010 4.6 gt with red leather
mine does it but hey it's not an issue..
__________________
Rudolph Hucker is offline   Reply With Quote
MustangForums
Ford Mustang
Paid Advertisement
09, 1000, 2009, 2010, 500, audio, ford, information, job2, muffled, mustang, noises, shaker, sound, systems
Similar Threads
Replacing Shaker 500 with All New Audio System ItsWookieTime 2005 - 2014 Mustangs 9 02-17-2008 05:23 PM
Front speakers in shaker 500? Mustang3GT07 2005 - 2014 Mustangs 25 07-18-2007 07:58 PM
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
