Sponsored by:
Sponsored by:
Shaker 500 audio noise
Old 07-27-2009, 09:11 AM
  #31
Frantz
Frantz's Avatar
How about if you adjust the bass level? Perhaps its an issue of too much power to the speaker driver? Shouldn't occure in a factory car, but it's not impossible.
Frantz is offline
Old 07-27-2009, 09:14 AM
  #32
Adam
Adam's Avatar
Tried every audio setting available (bass, treble, face, balance, etc) - nothing makes the noise go away.
Adam is offline
Old 07-27-2009, 07:27 PM
  #33
tomz
tomz's Avatar
Default Shaker 500 audio noise
A non nav Shaker 500 identification code:
Radio on and put the radio on an AM or FM channel.
Press 3 and 6 simultaneously.
Before it stops testing the speakers press 6.
Then press the UP button and you see the reference code.
I have: AR3T - 19C 158 - AL
That is apparently a Job1 ACM code. A Job2 ACM will probably have a different code, possibly the "AL" will change.
Whoever gets a Job2 ACM may be able to identify a "before and after" code change.
Tomz
tomz is offline
Old 07-27-2009, 07:56 PM
  #34
robinsonda1
robinsonda1's Avatar
Is the stereo that is in the Nav models in fact a Shaker 500?
robinsonda1 is offline
Old 07-27-2009, 07:57 PM
  #35
Adam
Adam's Avatar
Tomz
Great post Tomz! Confirmation from Ford or a JOB2 owner would be fantastic. Have JOB2 mustangs even hit the dealerships yet?
FYI, mine is also AR3T-19C 158-AL. If this number is on the outside of the ACM we will easily know what we are dealing with.
Adam is offline
  #36
Adam
Adam's Avatar
Yes it is.
Adam is offline
Old 07-27-2009, 08:00 PM
  #37
robinsonda1
Originally Posted by AJ_68
Yes it is.
Good, I like that system and the web site wasn't really clear about that.
Old 07-28-2009, 11:49 PM
  #38
skyboss_4evr
skyboss_4evr's Avatar
Guys,
FYI... my Shaker-1000 is making the same noise at no/very low volume.
skyboss_4evr is offline
Old 07-28-2009, 11:50 PM
  #39
Adam
Adam's Avatar
Originally Posted by skyboss_4evr
Guys,
Thank you very much for this information - you may be the first Shaker 1000 owner to chime in.
Adam is offline
Old 07-28-2009, 11:55 PM
  #40
skyboss_4evr
Sure thing. I could probably live with this, but if Ford does come up with an easy fix, I'd be all over it.
Quick Reply: Shaker 500 audio noise
